bmacf
Throttle Position Sensor?
Post by bmacf »
Hey everyone, this topic came up a while ago, but I'm looking for a few more details. I've heard that the Volvo 850 tps (sensor, not switch) will fit our V6 throttle bodies. Does anybody have a specific part number? I bought what I thought was the Volvo 850 tps, but it turned out to be a switch and not a sensor (Bosch part # 0 280 122 001).
FYI, if you want to install the flat-shifting feature of Msn-E, you need a tp sensor, not switch. This is because it needs the tp information to turn on the rev-limiting feature for flat-shifting.
Bill in Maryland
Bill in MD
'88 Alfa Milano Verde x 2
'77 Fiat Spider
zambon
Post by zambon »
I have been looking into this topic myself. Michael posted that a tps from a porsche 944 turbo will work. I think it even fits.
I made a list of potential candidates based on the catalog at my local auto parts store. They are all bosch six pin units. I think that they must be sensors (not switches) if they need six pins, but what do I know. I also do not know which way that they rotate, but here goes...
Porsche 86-89, 91-92; 0 280 120 107; $61 at autozone (the cheapest on the list). autozone part number tps-422
audi 92-99; 0 280 120 431 078 133 154
bmw 87-93; 0 280 120 402 13 63 1 707 320
audi 90-91; 0 280 120 407
porsche 89-92; 0 280 120 417
bmw 88-93; 0 280 120 406 13 63 1 708 605
audi 90; 0 280 120 424
bmw 92; 0 280 120 404
audi 92; 0 280 120 428
zambon
Post by zambon »
One more option in the first post of this link:
http://www.alfagtv6.com/bb/viewtopic.php?t=767
Reale
TPS
Post by Reale »
An alternative is to get the TPS from a 95 Chevy Lumina (Wells part number TPS140), around 40 US$ new, or less from a junkyard. If you take apart the stock GTV6 throttle switch, you can use it as a mouning surface for the Lumina one. You wire the Chevy part to the Bosch connector, and it works great with no mods to the throttle body whatsoever.
Pic here:
http://www.realemotorsports.com/rd/mega ... tpsmod.jpg
Ugly, but very reliable. You can even RTV the original TPS cover back on over it, if you want, or just seal the whole thing up.
-Al
Al Mitchell
Reale Motorsports
#82 E Production
Alfa Romeo GTV6
zambon
Post by zambon »
Nice work Al :!:
I bet you could get one of those at a junk yard for $5.
I am looking at going to a 75mm GM throttle body and I could most likely use one of those. I bet they have Luminas as far as the eye can see at Northern Wisconsin junk yards :D
Thanks
bmacf
Post by bmacf »
Hey Zambon and Al, thanks for posting some options for throttle position sensors. I had been pulling my hair out for months trying to find an alternative.
Zambon, for those off-the-shelf Bosch TPS's, do they require machine the throttle shaft to be a little shorter? If not, I'll probably go with the generic Advance Auto TPS. Otherwise, before machining the shaft, I think I might try converting a spare TPS to one with the Chevy innards.
And I'm looking forward to combining enrichment via MAP and TPS.
Thanks all!
Bill in Maryland
Bill in MD
'77 Fiat Spider
Reale
TPS
Post by Reale »
Hi-
It was funny how I decided on a Lumina TPS. I was messing with dis-assembled rheostats, pots, etc., trying to figure out how to shoehorn one into the stock throttle switch housing, when I was suddenly posessed by an urge to see what kind of TPS was on my wife's Lumina (yes, we owned one of those pieces of crap once). SO . . . I went over, identified, and removed it from her car (no, I did not ask first), and discovered (to my shock), that it would fit within the confines of the Bosch TPS housing (mostly). After I carefully replaced it, I went to the autoparts store and got one of my own!!!
-Al
Al Mitchell
Reale Motorsports
#82 E Production
Alfa Romeo GTV6
