cchan,
Use regular plumbers teflon tape, the 1/2 inch wide should do fine. A little trick I learned to apply the tape and not have it unravel is this; Hold the fitting in the left hand with the thread under your thumb, hold tape roll above the thread so that its like toilet paper coming off the bottom of the roll, put the loose end of the tape under your thumb and hold the tape so when you wrap the tape around you trap the tape not your thumb, start to wrap the tape away from you (if you put fitting infront of you thread facing away you'll be going counter clockwise), hold a bit of tension on the tape as you go, go around 3 times, cover the starting end of the thread but don't hang over the end so that the hole is covered.
this takes no time to do and forever to explain.
HTH,
Scott
HTH,
Scott
- scott.venables
82 GTV6 Restore
Hello,
So JJ arrived on Tuesday in town. Picked him up at the Airport and after lunch started the final completion of the Alfa. We changed the spark plug wires to Blue ones since they had a better reach than the black ones. Completed the Hook up of the Engine Management System tubes, Mounted the coil packs, and painted and tested the fans.
We needed to revise the throttle linkage since it is not like the Milano so we did another mount that worked propertly. Finally, we made a mount for the air intake tube. Everything is looking good and we had the alignment done today as well as 2 hours of Dyno for the intial set up and drove the Alfa. What Fun
Here are some pictures:
- Coil Pack Installed.JPG (172.97 KiB) Viewed 7924 times
- Alfa Fans restored.JPG (152.17 KiB) Viewed 7924 times
- Alfa Intake #1.JPG (154.94 KiB) Viewed 7924 times
- Alfa Intake #2.JPG (157.39 KiB) Viewed 7924 times
- Modified Throttle Cable Bracket.JPG (162.35 KiB) Viewed 7924 times
82 GTV6 Dyno
Took off after late lunch to bring the Alfa to the Interior Shop so that I can stay on schedule for JJ. Everyone who saw the Alfa was amazed with the paint and the restoration project. Your good JJ, nothing but compliments on your engine, suspension, and the engine noise. The Alfa started up ok and we actually drove the Alfa on to the tow truck and off into the interior shop. Still need to deal with the starter issue but worked so far.
Here are some pictures of the car being dyno tuned. I wish I had JJ's camera to take the picture of him driving to the dyno tune due to the tow truck delay. My AAA membership will not tow the Alfa anymore.
Who cares I could have driven to the interior shop but with no windshield and no registration yet I did not feel like taking a chance. The picture would show JJ's hair blowing like crazy on the freeway. JJ has alot of *alls to drive it to stay on schedule.
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
- Alfa Dyno Tune #5.JPG (74.41 KiB) Viewed 7845 times
- Alfa Dyno Tune #4.JPG (67.21 KiB) Viewed 7846 times
- Alfa Dyno Tune #3.JPG (57.75 KiB) Viewed 7846 times
- Alfa Dyno Tune #2.JPG (47.99 KiB) Viewed 7845 times
- Alfa Driven to Dyno Tune.JPG (33.54 KiB) Viewed 7845 times
Alfa GTV6 Interior Restoration
Went over some more details for the interior and how to do the dash. Joe needs to study this to see how he will do the dash. We will either do the "just dash" for the restoration or custom leather if it is possible. I picked out the carpet which will be wool from the Rolls Royce book and I just need to pick the headliner. Joe thinks that a custom Red Mesh and black background will match the seats. I can also go with a light off white suede for the headliner. What does the BB think would look good.
I also saw one front seat and and now that the Alfa is actually at the shop they will start working on this part of the restoration continually. I will only be working on the Alfa on the week ends again for my Hobby. We are painting the door locks and trunk lock since this needs to be installed before the interior. We will also be working on the electrial items such as the windows (do not work) and test all the other electrial items such as head lights, turn signal, interior lights, etc.
The tach does not work but I think this is because we need to wire it from the Gotech and the speedo. We need to source the Milano sender per the GTV6 tread. Finally, I need to redo the chrome rocker panels for the lower door entrance. Has anyone seen any custom ones that have the Alfa Romeo written on them. ( For example like the Mercedes Benz or BMW ones that are put in them from the Factory)
Here are the Final picture for today.
- Alfa to Interior Shop #3.JPG (49.52 KiB) Viewed 7842 times
- Alfa to Interior Shop #2.JPG (49.64 KiB) Viewed 7843 times
- Alfa to Interior Shop.JPG (53.31 KiB) Viewed 7843 times
- Mezevenf
Ooo looking nice!
What coil packs are they? I have the VR6 unit that was sent with the engine, but the plug are basically taped on because they do not fit the coilpack, and any VW leads that do fit are too short for the engine.
If you could find out that would be great![Very Happy :D](./images/smilies/icon_biggrin.gif)
1985 GTV6 2.5L 12v V6 - Red
1999 166 3.0L 24v V6 - Red
NightSpec
NightSpec
GTV6 Restore
Hi Mezevenf,
Thanks, it took awhile to get the plug wire set up ok. We used two sets of wires to make one set since two plug wires were too short. To the best of my knowledge this is the only way to solve this situation. The plug wires were HP over the counter wires. We used Mitsubishi Pajero 6 pack coil-pack for my conversion. Hope this helps with your project.![Very Happy :D](./images/smilies/icon_biggrin.gif)
- Mezevenf
I might have to mod some Golf VR6 leads to be long enough for mine, that would work.
Thanks
Keep us all updated.
Thanks
NightSpec
NightSpec
- scott.venables
- Mezevenf
Insanity?cchan wrote:I can covert back to a Stock GTV6. Can't really see me doing this but just in case. Never know what the future may bring?
NightSpec
NightSpec
82 GTV6 Restore
Hi mezevenf,
My wife would agree with you on the "INSANITY" only from a different point of view. She feels that Cars are a waste of $. I am just keeping everything to justify my conversion. As you know, maybe not on this BB so much but their are those who think a restore uses all OEM parts and originality.![Wink :wink:](./images/smilies/icon_wink.gif)
82 GTV6 Restore
We worked a little on the Alfa this Sat. Looks like we are going to be delayed though. The dash seems to be a problem and Joe does not think he can do a good job with leather due to the unusual shape of the dash. Therefore, it looks like we find a new dash in black (Probably impossible), go the just dash route ( 5 weeks), or follow the refurbish of the dash with as detailed by the thread in this bb with the foam and truck liner (might not follow directions correctly and look bad). What have others done with their dash??
We took out the headliner and picked the new material. We are going with off white headline to keep it the orginal color. We also covered the body so it would not get damaged. We will remove the dash this week and if anyone has any pointers we would appreciate it.
Finally, has anyone used dynomat for the interior of their Alfa for sound and heat insulation? We are thinking about the best way to do this part of the restoration. Don't want to add alot more weight but still want a comfortable interior.
Here are some pictures of the status of the interior.
- Interior Restore #5.JPG (47.93 KiB) Viewed 7584 times
- Interior Restore #4.JPG (41.78 KiB) Viewed 7585 times
- Interior Restore #3.JPG (29.78 KiB) Viewed 7586 times
- Interior Restore #2.JPG (38.97 KiB) Viewed 7585 times
- Interior Restore #1.JPG (46.45 KiB) Viewed 7584 times
Dynomat
Hello mate.
I dynomated the entire interior and under the hood of my Alfa. It ways next to nothing, just a rubbrizd compound and a thin veneer of batting which also deflects heat. It has a nice self adhesive on it and is very easy to work with.
I highly recommend it to improve insulation, reduce rattles, and improve stereo quality. However, it will muffle the sound of your GTV-6 purring. If you do go with it, double down on the drive shaft hump as it will elminate to a degree the heat which radiates up near the shifter.
Overpriced product, but still worthwhile.
Best wishes,
Richard
Best wishes,
Richard
