Good choice going back to original color.
Googling for GTV6 1985 gives mostly one color body without plastic bottom as result.
Re: Andy´s ex-white GTV6 (CZ) - pearl green
..and here comes the rosso
What place are you buying spare parts, such a fuel filters/pump and rubber window seals ? I know about myalfa.eu and alfa-servise (and highwood alfa). Basicaly I need the source as local as possible (EU)
Also, after sitting for few years I suppose the fuel tank should be drained first. Shall I remove the tank or disconnecting at the fuel pump is usually enough?
- rosso.jpg (83.7 KiB) Viewed 7749 times
anyone interested in MSD ignition set? I have purchased it last year for my project GTV6 car, but it seems like I will keep the original ignition instead. The kit contains MSD 6TN ignition box - MSD Blaster Coil 45kV High Vibration - MSD Tach Adapter (for the GTV6 Rev counter still to work properly) - MSD Soft Touch Rev Control with different plug-ins for 350 €
- MSD 6TN.jpg (231.24 KiB) Viewed 6724 times
