Jarle
Post by Jarle »
The 75 is just amazing. Best looking transaksel I have ever seen, and with 18`s......wow :D
Jarle
LENZ
Post by LENZ »
Some updates on my 75 24V
new brakes front and rear
and a pic of the new 166 3.0 V6 24V engine in my 155 V6, with a 156 6 speed gearbox
155 3.0 V6 24v Q2 NovaCorse
Lenz,
Which motronic are you using? 155 or 164 24V? 164 24V makes more sense since you have both AFM and coil packs.
Very interested in the conversion for my car as well.
LENZ
Post by LENZ »
Zamani, it's a 166 engine with 164 24V M L 1.7 electronics.
The 155 with the 24V and 156 gearbox is a great combination, the car really goes, at this point i prefer taking the 155 to the track because it is faster than the 75 with the same engine even after i installed a TS box.
matt
Post by matt »
that is one great 75/Milano Lenz, with the new brakes did you change master cylinder too? I'm curious if you used that 25.4mm BMW one and your results.
Thanks Matt
LENZ
Post by LENZ »
Matt i used the 25.4 mm ate bmw master and it works great with my set up, with the oem master i hardly had any pedal, but with the 25mm the feel of the pedal is so much better than it has ever been before. Almost as good as on a modern alfa romeo. However the ate needs a rebuild, because it has probably been lying aroudn to long.
matt
Post by matt »
Excellent, great to hear your positive results :D
Jose_76
Post by Jose_76 »
Lenz, what BMW model does have that Brake master cylinder?
'84 Red GTV6 3.0
matt
Post by matt »
Hey Jose 76 its a 7 series BMW E 32, 25.4mm ate but only 2 ports
more stuff in thread- Brakes-Brake booster and MC solutions
Jose_76
Post by Jose_76 »
Thanks Matt!! :wink:
'84 Red GTV6 3.0
