Huge step forward today, dropped in the engine for the first time!
Everything fits, big relief!
Short way from the FMIC to the throttle, just a 90 deg elbow and Bob's your uncle!
Just need to figure out where to put the dump valve...
Nice clearance all around the plenum, nice. TS throttle body, 70mm.
Yes the compressor housing is quite large, what would you expect?
Quite tight to fit in the wastegare aqtuator as well, hopefully it won't hit the body due to engine movements.
Overview of the engine compartment, notice the forward move of the turbo compared to the stock 75T manifold I use as the inner part of my fixture.
Naturally the alternator doesn't fit in it's usual place and will be moved to the right hand side, it's been positioned there for years in this car actually.
Moving the turbo forward helps if you want to build a nice downpipe, will probably make the life a little easier for the brake and steering components too...
Nice and roomy under the plenum, for now...
Another shot of the turbo...
Next task: Design the cooling system. Where do I put the pump for instance? Hmmm...
