alfascort
My alfa powered Mk1 ford escort
Post by alfascort »
hello im colin from england
finally iv managed to find a site with real info about the alfa transaxle setups
here is the car im currently building i picked it up along the line as a half finished project
its a mk1 ford escort with running gear from an alfa 75 with a 3L V6 but i do have a set of 24v heads that im going to attempt to fit to the 12v engine
also using 4pot front brakes from an RX7
here are some pics
Space Frame Mk1 Ford Escort with Alfa 75 running gear
Hi Colin,
That's some beast you got there.The engine is certainly well back from the front axle !!
Would be interested to see how the back is configured. Who did the job? Has it been campaigned before ?
alfascort
Post by alfascort »
here are some pics of the back end
dunno who started building it but i dont think it was ever used as it was never completly finished with the space frame ect
Giulietta24vTT
Post by Giulietta24vTT »
WOW man this is an amazing project! :twisted:
Good luck!
BTW i'm not sure about the 24v heads on the older blocks, someone here will enlighten us later I suppose :wink: .
Merry Christmas!
Chen S
ex Giulietta 24V Glenwood TT.
Thanks for the rest of the pics Colin. Good luck with the project. :)
alfascort
Post by alfascort »
cheers for the comments :)
ill keep you updated on the project as it progresses
im looking forward to spring so i can get back into working on her more regularly :D
