Thanks for all the positiv feedback guys! It really means a lot!grant wrote:Your car is gorgeous! But what makes you think the shocks are going to solve the understeer?
Regarding the understeering, everyone I talk to tell me that the Koni-shocks doesn't work on the transaxel-cars. Appearently they are way to soft for spirited driving.
My experience also, is that they feel harsh and uncomfortable over small bumps in the road at low speeds, but when you really start pushing it they just become soft and making the front dip and lose grip....
I've had Koni's on other cars where they have worked very well, but I don't think they are suited for the GTV6/Milano and so on, at least not with the standard torsionbars...
I think that my very stiff front sway bar (30mm) adds to the problem of having too soft shocks
This is why I think a good solution would be to get some stiffer shocks. A friend of mine had almost the same setup as I do (rim-size, tires, front sway bar+++), but had stiffer Bilstein shocks and a stiffer rear sway bar.
This car handled beautifully!
I'm open to other suggestions as well on how I can reduce understeer, and preferably get some oversteer....
This is how my car i set-up:
-Wheel-allignment according to instruction manual (I think...according to my very good mechanic wheel allignment is good)
-Stiffer rear springs, and lowered about 40mm rear and front.
-Yellow Koni's front and rear
-30mm front swaybar with uniballs
-Wheels are 9x16 and 7,5x16 with 225/45-16 at the rear and 205/50-16 at the front.
