Hi, Ive replaced the relays, and have an un-molested car ( ie no-one has butchered the electrics ) but I am getting zero current to the motors... any clues where else to look ? Fuses checked as well.....
thanks
- Alfa GTV6 NZ
Re: GTV6 Electric windows not working
it should be fairly easy to troubleshoot.
check that you have 12v at the fuses.
then pull the switches from the centre console and check for 12v and correct operation.
if all that is ok, check the connections inside the door.
good luck.
good luck.
