borto
identification plate under bonnet missing
Post by borto »
A few years ago I moved to Italy bringing my GTV6 with me from abroad. Because of lack of time I never registered the car on italian number plates.
Now the time is there, but i discovered that the identification plate, with the chassis number, weights ecc. under the bonnet is missing. This plate is required to register the car. According to the local AR dealer it is not available as a spare part.
Does anyone has a suggestion how to get this identification plate? I have been told that "original reproductions" are offered around, but where?
thanks in advance,
Mario
ar4me
Re: identification plate under bonnet missing
Post by ar4me »
On US spec cars this plate (or what I think you are referring to) is mounted at the drivers' door jam - on the B-pillar towards the bottom.
Borto
If the suggestion from jes doesn't locate the plate, visit a motor wrecking yard (or equivalent) and simply buy/remove that plate from the car being wrecked and fix it to the location it is supposed to be for these cars in your country.
Panel repair shops do it all the time if a vehicle is damaged badly enough to damage the original plate.
Capito?
Need a correct chassis number though...
if the VIN number is on the plate you might have a problem... :?
Then you need to make a new plate.
Search for a plate from another (same make+model offcourse.. :roll: )car and use that one to make a copy. Get some company to scan it into the computer and print it onto a piece of aluminium. Then cut it to the same size as the original. after that you just have to punch in the VIN number and attach it to the car.
Not an easy option... :(
ar4me
Post by ar4me »
Here is a pic off of eBay from a gtv6 showing the location of the VIN plate on a US GTV6 - there is also a smaller plate in the window with only the VIN number.
SimonB
Post by SimonB »
The VIN is stamped on the bulkhead too at least on my UK model.. I needed to clean this up so the inspector could read it before they let me register it in Spain. I also don't have the chassis plate but in Spain they let me register it because the VIN matched the documents. I am going to try to register it in France when I bring it over, I might be looking for a plate too if they turn out to be too picky. Good Luck!
05 Corolla daily driver
borto
Post by borto »
In Italy the identification plate is needed above all to register the car at the ASI.
This is an official classic car register. When it is registered at the ASI you do not pay road tax and can get cheap insurrances.
Is there anyone who could post a picture of the identification plate of a european GTV6. So at least I have an example how it should look like.
thanks in advance,
Mario
borto wrote:In Italy the identification plate is needed above all to register the car at the ASI.
thanks in advance,
Mario
Had a look under the hood of a friends GTV6 yesterday, didn't have a camera with me but today I'll sanp a pic (if I remember... :roll: )
There are actually two plates but I think when we look at the pics together it will be clear what you need. :)
Here you go.
borto
Post by borto »
Thanks Mats,
Now at least I have got an idea how it should look like.
I am still looking for someone how is able to reproduce it with my serial number.
If anyone has an idea please let me know.
Mario
Omawari_San
Post by Omawari_San »
I am looking for those two plates aswell. Any source or idea for a solution?
Or maybe a clearer picture, so I can get it custom made at some sign-maker-shop?
