Jose I
crudy valves
Post by Jose I »
How the heck do you get that crudy varnashy crap of the valves.
tried soaking it in super hot water mixed with heavy duty machinery degreaser( I swear I heard one of the valves laugh at me) :x :x
Drive'm Hard
Got a bench mounted electric wire brush?
You're right. I think I heard a little snigger myself.
Murray
Post by Murray »
Jose I had great luck with combustion chamber cleaner.It usually comes in an aerosal can.What I did was spray the whole can into a coffee can and soak the valves for a couple of hours.After that I was able to remove most the crud with a toothbrush (my wife's :lol: )This also worked well for my pistons.Be sure to inspect your valves very carefully once they are clean.Use a magnifying glass and pay particular attention to the exhaust valves.You're looking for hairline cracks which usually radiate in from the outside edge.Not uncommon.
Jose I
Post by Jose I »
Thanks guys. I'm going to try the chem. way first if that don't work I'm hitting the wire wheel. :twisted:
Drive'm Hard
I use a rotating wire brush on either a bench grinder or an electric drill. That works very well.
Greg Gordon www.hiperformancestore.com
matt
Post by matt »
I hear em too Jose I...........! 8) ,
wire brush an drill shut em up!
dirty valves.JPG (129.73 KiB) Viewed 5116 times
