1995cc is the Lampredi engine. Iron block and so on.
1962cc is the old hopped up Alfa mill
1970cc is the new Fiat/Alfa modular 16v engine (as in newer TS and JTS)
- Maurizio
hmm, posted twice
Banned.. ?
Daily donky.. ==> BMW 325d ![Image](http://images.spritmonitor.de/1106541_2.png)
E36M3 (3.0) Ringtool
==> definitely BANNED!
![Wink ;-)](./images/smilies/icon_wink.gif)
- Maurizio
By Zamani on Unrecorded Date:
Bore X stroke
75 TS 84 x 88.5mm = 1962ccm
155 TS 84 x 90mm =1995ccm
I suspect a different crank and the heads must
have been revised. Some guy in the US
bought both heads and he confirmed that the
155 TS had a narrower angle head.
the 155's have the cast iron bottom end, heads are interchangeable. Here the Dutch trofeo like the 155 head over the 75 for it's better flow due to the narrower angle
Banned.. ?
Maurizio,Maurizio wrote:Some quick math.....
Offset piston pin 1.75 mm
Skim piston crown 1.6 mm
And a 3mm 45 deg chamfer on the outside +
all together will added give 1:11.5
there is also some more material that can be lost, as there has to made some more valve relief (155 have the valves in a steaper angle) .
I too am interested in a similar build up. How was CR of 11.5:1 determined?.
By observation and/or calculation?
Was this established from a previously done engine?.
Were the combustion chambers cc'ed and what is the typical volume for TS 75 head chamber and a 155 head chamber?(1st component of CR)
How was volume of piston above the block deck calculated (2nd component of CR) with a burette and a dam of known volume?
Just to clear up my confusion about the piston pin (height) relocation(offset?). I might assume that the pin is being raised higher on the piston (micke's numbers indicate it was lowered by .5 mm in relationship to ring lands/ you show 1.75mm, up or down?) to lower it in the bore to accomodate the longer rod length and you not wanting to remove all of that 4.7mm of extra height although some of that height is being used to bump up the CR.
You mention "rod bore offset", do you mean the hole in the rod bush will be bored offset up or down and not concentric with the rod end itself? please explain. Up is bad, down is better
I don't think you mean pin "offset" or "rod bore offset" do you mean maybe just pin height (relocation) specification? please explain how this will be done.
To me "pin offset " is normally the dimension of how far fore/aft of the vertical centerline of the piston the pin is. This move is to reduce thrust forces on long/ short ? stroke motors where rod angularity needs to be reduced?.
Also you mention "more that can be lost " or must be lost to accomodate steeper valve clearance. Was this extra gained volume calc'ed into CR.
You mentioned 155 pistons on the way ( EU purchase or US?), will you rework pistons or custom order similar to the Arias with spec's all provided by manufacturer with no additional work. What is cost of stock 155 piston set with additional work performed versus custom pistons. Which brand are you purchasing. What kind of numbers made you decide the way to go?
Ross
Ross Gallichotte
'73 2000 GTV
'69 1750 GTV
'61 Guilietta Sprint
'73 2000 GTV
'69 1750 GTV
- Maurizio
Ross,
first of all this engine has never been built (at least I know off).
I have never rebuilt an engine , but when you start, you got do it right.
I have found a machine shop chef who is very willing to help on my wild plan. (and who has a weakness for alfa's, he owned a 1300 gtv which revved 9000 rpm all the time
Piston pin offset I meant the hole in the rod. (down)
CR calculation was done theoretical
So combustion camber volume would be (stroke x bore) / 10 on a standard engine.
To get 1:11.5, the piston has to move up 1.35 mm in the combustion chamber.
Valve relief has to be altered due to the different valve angle of 155 and 75.
The machine shop ordered a standard 155 piston to see what we can do. (I'm from the EU) This would then be reworked to go into my engine
more to come..... It is at the moment just an idea
Banned.. ?
- Maurizio
liners are the same from a 155 TS 8v, 164 TS and the 75 TSZamani wrote:Just curious, that means the 155 TS 8V had a different crank than the 75 TS? It seems that the bores are the same? If so, seems kind of dumb for Alfa to do that. Changing cranks just to go from 1962cc to 1995cc?
Banned.. ?
- Maurizio
Who can tell me the exact length of a TS or 2.0 Nord conrod from center crank to center piston pin?
Banned.. ?
- Maurizio
OK thanks, knew about the mm length difference, but will measure what is in my problem engine. There was slight exhaust valve/piston contact and I am looking for a cause. Timing was ~2 deg early but still should not be a cause for contact.
Banned.. ?
- Maurizio
Removed the cams, put the head on its back and filled the combustion chamber up with some very thin oil. (measured cumbustion camber volume also) And after two days only one exhaust valve leaked a very small amount of oil into the exhaust port. Contact must be very marginal, not to bent a valve.
Is the exhaust timing that critical, is 2~3 deg early enough to let the valve hit a piston? Or do I have a head which is skimmed to much.
Banned.. ?
Maurizio, here's a very practical and reliable way to measure valve to piston clearance on an assembled engine: Bring to TDC overlap phase (both valves open) and wedge a flat-blade screwdriver between follower and cam body. Twist the screwdriver so as to push down the follower until the valve contacts the piston (still at TDC) and there you have it: valve to piston clearance! Do this for both valves and record. If you repeat after retorquing the head, you will see less clearance! I once went from 2,2mm down to 1,4 just by retorquing 3 times to 10,5kgm (2liter Nord). You are safe with at least 1,5mm intake and 2mm exhaust with good valve springs and no 8000rpm trips!!!
