Timing Belt Position on Pulleys
I recently did a water pump & timing belt R & R. When I pulled the covers, I noticed the old timing belt was not riding completely on the pulleys. When installing the new belt, I slid it to about center of the pulleys. Now it's back to the front of the pulleys approx. 1mm over the front with about 6.5mm of the pulleys exposed in the rear. Is this normal or is the belt line up guide out of whack? I don't like where it is now.
Oh yeah, I left the front covers off to watch this and the front crank seal which has a slight oil leak which means taking everything back offf. Practice, practice practice!!!!!!!
- GTV6 TB Pulley Position 1.jpg (69.44 KiB) Viewed 8741 times
Regards,
N. G. Brooks Robinson
'84 GTV6
'84 M635CSi
'84 GTV6
'84 M635CSi
I was checking out the TB today and tried to reposition it by sliding it more centered on the pulleys. No luck after cranking the motor. I don't like it sticking past the pulleys and it's too damn close to the crank pulley for my comfort as well.
Inspection of the front crank seal and I think I can remove it w/o removing the cover; I hope, but we'll see. It's a slight leak but I'm compelled to repair. Hate leaks.
Regards,
'84 GTV6
'84 M635CSi
'84 GTV6
'84 M635CSi
P,
That could be a possibility as the mechanic owner I was told rebuilt the motor. I wonder how to check this out without a teardown. The engine is solid and runs like stink. Just nervous rev'g her with the belt hanging out. I remember my '83 years back didn't have this situation.
From the pulley appearance, it appears to have been run like this for some time.
Regards,
'84 GTV6
'84 M635CSi
'84 GTV6
'84 M635CSi
maybe you could have two round thin dish-like plates machined to mount to front of cam gears (similar to the washer on the crank gear)
they could just nudge the belt back a little probably without much wear...
would have to change belt more often i suspect
easier than resurfacing the heads.....and you would probably feel much better not worrying about losing your valves
Take a look at the distributor/oil pump drive pully and check if it is running true. I have had to replace a bearing in this due to too much belt tension - had about 3mm of float at the pulley and the angle that this caused would push the belt out on mine about as far as you are saying.
Mine was caused by a blocked oil gallery to this bearing.
Daniel,
I'm not following you regarding "a blocked oil gallery". Where is this located? Can you elaborate on this. My motor has the late model mechanical belt tentioner. This checked out OK when I did the TB change and the belt doesn't appear to have too much tension.
If the distributor/oil pump bearing is bad, I don't think I'll have much trouble R & R'g as I have a press.
Regards,
'84 GTV6
'84 M635CSi
'84 GTV6
'84 M635CSi
