Engine support stand
Hi Gang,
Has anyone used one of the standard types of engine support stands that bolt to the back of the block using the torque tube bolts? (see "stand" pic right hand side). I noticed in the workshop manual they show a different type of support using the side of the block by the side mounts. (see attahced). Just wondering if the first type would work since these are widely available here in the US.
thanks
AlfaBeta
thanks
AlfaBeta
- stand.gif (4.39 KiB) Viewed 9714 times
- engine support stand.doc (53.5 KiB) Viewed 9717 times
Yes I used that type of stand- no problem.You have to use some washers to get everything snuggly bolted up,make sure that you don't bottom out the bolts in the engine block holes.I also used a wooden support under the oil pan as there is a lot of weight hanging out there.
- ENGINESTAND.jpg (28.83 KiB) Viewed 9700 times
Currently I have both a Nord and a 2.5 v6 hangin on the reaf flange in one of those engine stands with four arms.
Seems to me that the person that designed that stand usually plays around with big blocked engines as you really need to play around with those arms to get it to fit.
Only problem I have with the rear flange mount like Mats is that the flywheel ,seal and bellhousing has to be ass off the stand.
This engine is on the stand here,but the other side manifold does not fit,so I still have to ass. the manifold off the stand..
Rather a manifold than flywheel,somehow i need to hold the crank to torque the flywheel bolts..
- DSC01228.JPG (145.41 KiB) Viewed 9561 times
I used a rear flange stand from Harbor Freight. Cheap piece of cr*p, but after some welding, it worked great. Bought some 11+ hardness metric bolts at local hardware. The thing is, you need to put on and take off the bell housing while engine on crane. Also, get a four wheel engine stand, much better balance....and therefore safety. Finally, don't trust the stand to hold the engine. Always put a jacked block underneath to support the engine when not turning it ( and remember, when turning, these are top heavy) You can get a floor jack in easily under the engine on the U-shaped four wheel stand.
I know you can't see everything in the photo, but trust me, it's there!
- stand.JPG (94.64 KiB) Viewed 9528 times
Harbor Freight engine support stand
Hello,
I'd like to get the motor out of my GTV-6 parts car before our upcoming house move. Once it's out, I'd like to attach it to a Harbor Freight 1000 lb. engine stand (the 4-wheel model, about $50). How would that stand mount to the V-6 motor? What is the most straightforward way of doing that? Fabricating some sort of mounting adapter plate, maybe?
All advice appreciated.
Charlie Koster
San Gabriel, CA
Charlie Koster
San Gabriel, CA
Re: Engine support stand
It is nearly the same one I have. It has 4 adjustable slides. Go to home depot or hardware store and pick out some correct sized (width/thread and length) metric bolts of at least grade 8 AND about 20 large washers to fine tune the fitting up. Yu will need to have the mount plate off the stand to get the right sized bolts.
Stand works out fine. I am getting another one this weeked for second engine project.
