im looking for a 916 gtv 24v engine gasket / seal kit.
IAP and centreline both have a listing for the 164 24v engines but not the 916 gtv. does anyone know if these gasket sets are the same? or the best / cheapest place i can order the correct kit from?
cheers, Brad
916 gtv / spider 24v gasket kit
Re: 916 gtv / spider 24v gasket kit
www.ebspares.co.uk might be able to help you out..
thanks!
i rang a shop here in australia and they wanted $550
eb have one for $330 au not including delivery (+ $20-30?) which is resoanble but IAP have one for $295 deliverd to my door (for 164 tho). i would really like to know what the actual differneces are between 164 and 916 series engines?
One of the differences is that the 916 GTV engine has a chain-driven oilpump. The 916 GTV engine is actually more like an 166 engine.
I believe the head gaskets are different, or at least the one on the startermotor side.
The thermostat and housing and related parts are also quite different.
