Re: Need s some advice on an Alfetta GTV 3.2 V6 24v conversion
Looks great. How low is the oil pan?
Looking really good .
Hi 75evo, it sits about 10mm lower than the original lower sump.
I would like to thank all the guys on this website that had help me on this conversion till now.
No doubt I will be needing some more advice in the future as I progress on the GTV6 completion.
What ECU are you using mate? Autronic, Adaptronic or Haltech?
Did you take any pics of your front thermostat adaptor ?
Hi 75evo
I will be using a Gotech Pro X ECU.
Hi Kevin I did not take a photo of the modified Thermostat housing by its self, Below is a photo of the housing on the engine.
- IMG_2008.jpg (247.33 KiB) Viewed 7409 times
Loving those ITBs, did you get them from AHM?
Yes got them from AHM,
Very happy with the quality.
Very neat ! Is this originally a 2.0 shell ? What bonnet ( hood )are you going to use as the 2.5 one does not fit on those throttles . Most guys use the 3.0 bonnet .
The sound those throttles make when you behind the wheel is glorious . It makes all that hard work worth it all !
Hi Kevin,
Yes it was a 2.0 shell,
Had to do some changes on it to fit the V6.
I have fitted v6 drive line and hubs with the 3.0 larger drive shafts .
3.0 bonnet would you have photos ,
Just removed some rust from the doors and bonnet fitment was next. I wanted to fit the 2.5 bonnet , I have not yet tried fitting it.
Also depends on type of filters you are going to use . I can give you full sketch of bonnet or you can order one from a chap in UK who has good moulds for the bonnet and larger spoiler . If you do i know another chap in Oz who was going to order one so maybe you combine order .. or just simply modify your bonnet like the green 24v Gtv of Ale drig who is on forum .. probably easier and also good looking as you can do away with the plastic piece
- image.jpg (20.62 KiB) Viewed 7361 times
Hi Kevin ,
I am going to fit filter socks over the throttle rams.
I don't know what I will do yet with the bonnet.
I will work it out once I try fitting it.
Mite do something different, refer picture.
- Picture 456 (1).jpg (141.45 KiB) Viewed 7340 times
Love the hood scoop, should go well with stickers like "Git 'er done!" or "BIG BLOCK"
- SydneyJules
Now work Alfaa1
I believe you’re in melbourne? Where about a?
My conversion and project is finally getting some momentum, although I’d love to have a look at yours.
May also be able to help with an SA 3.0 bonnet as I’m also going to run aHm throttles and An SA bonnet on my car.
Jules
Jules
Jules, come on already, update your thread. It's on here somewhere.
