Crank case ventilation and negative pressure
I think there's merit in creating negative crankcase pressure. But maybe it has more to do with seal longevity as opposed to "free horsepower". I don't like the fact that hot crankcase air gets into the intake. For a road car, emissions forces you to do this, but for an off-road car, I question the need for routing hot oily air back into the intake.
Article relating to crank case pressure
https://dsportmag.com/the-tech/quick-te ... re-part-1/
Actual dyno tests wti various crank case pressure setup
https://youtu.be/2fg0eZzRNZI
KevinR
Re: Crank case ventilation and negative pressure
Post by KevinR »
Interesting.
