Page 2 of 3
Re: Alfa romeo v8 engine
Posted: Tue Jun 15, 2010 10:01 pm
Do you have any engineering background?
I might know a Montreal engine for sale (in pieces) if you're intrerested?
Posted: Wed Jun 16, 2010 5:00 am
by Micke
It CAN be done!
Worthwhile - hardly.
Engineering challenge - Definitely.
I see the budget being the biggest problem. And it will consume a lot of time.
I did see a loooong time ago someone making a V8 from two inline 4's. Can't remember which brand or where.
And this is how the powertech engine is made. 2 Hayabysa heads.
http://www.powertecracing.com/pdf_downl ... engine.pdf
As you'll be creating a bastrad (in the good sense) anyway and being mid engine you might have space to keep one bank's exhaust in the middle. The new BMW turbo has both exhaust there so it can be done.
http://themotorreport.com.au/wp-content ... -tmr-1.jpg
If you have a problem with issues mating any engine to any gearbox this project is not for you. That is considered fairly easy.
Anyway, good luck.
Posted: Wed Jun 16, 2010 5:14 am
by Dennis
For a small series I would use the Montreal engine to keep it Alfa, otherwise the powertec V8 is just brilliant. 10,500 rpm Baby!!! It's light, it's dry sumped and no slouch with 360 hp...... Just mill some nice Alfa camcovers and have idiots call you a bastard.
By the way.... If you are not going to sell kits of that 33 body, I will have to come to SA and get them. I'm warning you, don't get in my way
Posted: Wed Jun 16, 2010 12:16 pm
by 74Spider
Hi Mats: Yes I do, details would be great - thanks.
Micke: Thanks for the links - be nice if it looked like the Powertek unit ! <dreaming>
Dennis - I'm with you. It's a hell of a unit - nice and compact too.
Regards,
74Spider.
Posted: Thu Jun 17, 2010 3:34 am
by grantleyrich
How about an engine from the current 8C?
Better still, how about getting hold of an engine from a recent Maserati and changing the cam covers? After all, that is where the engine in the 8C came from so there is a precedent
Posted: Thu Jun 17, 2010 4:49 pm
by Alfa GTV6 NZ
on crazy v8's check out this local company
http://www.synergypower.co.nz/
They did really well at the Chili Bowl in Tulsa Oklahoma.
Posted: Fri Jun 18, 2010 11:47 am
by kevin
Thats a good leed on engines. When jules gets here on Wednesday im gonna take him around to see this 33 replica of Peters
Posted: Sat Jun 19, 2010 1:06 pm
by 74Spider
Hi Verde,
If you have any pics of the replica that would be great.
74Spider.
Posted: Wed Jul 28, 2010 1:09 pm
by slyalfa
it might be a bit strange but if you keep the 2 cranks and tied them together with a big chain or gear with one running backwards. you would still need to rework one head. or have strange plumbing.
but this way you have more or less 2 motors side by side. you can slant them any way you want. but use all stock parts.
might be able to go large intake valves. and make the out on both the stock intake valve size. just to keep them equal. it would be oversize on the out but would work
having 4L would make up for some of that.
Posted: Tue Aug 31, 2010 12:23 pm
by t16
IsĀ“nt it possible to find a suitable v8 like bmw or another alloy block with cam chain and put two nord heads on?
Then the chain drive is cut of one of the head and welded on the other side.
Posted: Tue Aug 31, 2010 11:53 pm
by Typhoon90
Welding up blocks can be done, custom cranks are not a huge issue for the right people. Cams, as long as you can make stock blanks work, they can be ground to whatever you want.
The big issue as people have said, is the cylinder head. I reckon the cheapest way to do a reverse cylinder head would be to slice up a head, put it back together with intake and exhaust around the right way, fit the cam chain box then make a sand pattern and cast it. Welded up cut and sliced heads tend to be a bit fragile.
It's also not as easy to just cut and shut the can chain box onto another head, cams usually run a wider bearing at the cam chain end, for the greater side loads they see.
Then "all" you have to do is sort out cooling and cam/accessory drive!
Me, I'd just go buy a Porsche V8 and be done, if I wanted a quad cam engine.
Or, there is the Lotus V8......that is one beautiful engine.
Regards, Andrew.
Posted: Fri Sep 03, 2010 2:00 pm
Yes good call but I think the challenge is the name of the game here don't you think?
Posted: Sat Sep 18, 2010 3:18 pm
by Flying Machine
What a project! Could turn a man grey!
Early Tipo 33 cars (T33/1 and T33/2) had 2 litre, 4-cam, 2 valve per cylinder, flat crank V8s to a design by Carlo Chiti.
The Montreal motor is derived from that engine but differs in capacity (2.6 l.) and being for a road car may have a 90 deg crank and aptly altered cams; the cam and valve counts were unaltered.
It depends on the era of Tipo 33 you are replicating, but perhaps a Montreal motor would not be so inappropriate. If indeed it has a 90 deg crank the exhaust sound would be rather different. Who do you have to convince?
There's a trade-off between "noise authenticity" and the avoidance of the secondary vibrations that come with flat cranks. Your call, but the vibes can do a lot of unseen but important damage to a car that may not get the frequent dismantling and detailed checking/crack detection lavished on an active works race car.
If you can get hold of one, the engine from a Lancia Thema 8.32 is derived from a Ferrari V8, 32 v/v flat crank unit but has a 90 deg crankshaft.
On deriving a V8 from 4 cyl Nord parts: port geometry, valve seat sizes and particularly the cast-in cooling provisions for the exhaust valve seats and valve guides all strongly suggest that reversing the functions of the ports is not a good idea. Better to slice off the timing chain case and tappet well drain zones from their respective ends of the casting chosen for the right side head, turn it front to back and fabricate new ends to match the oil drains and cam drive casing(s) of your - all bespoke but the liners and conrods - bottom end.
Challenges galore, not to mention building chassis, body, running gear.
Good hunting. I'll get a hat so I can raise it when you win.
Posted: Sun Sep 19, 2010 2:21 am
HAHA!
Seriously though, nice info post and welcome to the forum!
Posted: Sat Oct 02, 2010 6:49 pm
by storm_rider_
Talking of a fiat v8, I remember seeing a picture of a guy splicing the 8 valve twin cam heads onto a rover v8 block. spacing was very similar and the later twin cams are reverse flow so you can have two 8 valve heads both with the inlets in the middle instead of reversing one or working around that. Sure i have a picture of the engine it somewhere to. Not sure whether he ever got it to run though.
