Fast question: How thick are the Reinz, Goetze and Spesso gaskets? I have new Corteco and Payen gaskets here and their thickensses are 1.75mm and 1.85mm uninstalled. I also have used Payen which is 1.75mm, which was too high for my engine.. Maybe it would be 1.7mm as installed, so maybe Corteco would be 1.6mm then?
Navalinea gasket is 1.6mm, but the optimal would be 1.4-1.5mm in this case.
Re: TS bottom end rebuild
Kimmo / alfatune.fi
- Maurizio
I have a used Reinz laying around and that is 1.6 [mm]
Banned.. ?
Daily donky.. ==> BMW 325d
E36M3 (3.0) Ringtool
==> definitely BANNED!
I found that reinz has 1.4mm gasket for Nord engine, so I ordered it. Let's see..
Kimmo / alfatune.fi
The gasket is already at 1.4mm before compressing. Probably it's around 1.3mm when on use. Looks good
Kimmo / alfatune.fi
