Jose I
Valve tappets
Post by Jose I »
Is it really neccesery to change the valve tappets? mine seem to be in very good shape ,they still have very clearly a circular pattern steming from the very middle of the tappet to the edge like the rings on a tree.
So should I chuck these or keep them.
and how about valve spring retainers and keepers do these stay or get replaced.
Drive'm Hard
Murray
Post by Murray »
Jose if the plating on the tappets is intact ,no chips erosion etc.I,d keep them.The keepers and retainers can also be retained.
Jose I
Post by Jose I »
Thanks Murray .
damn you don't play around you see someone needs something answered and BAM your there .
Once again thanks alot Murray MAY THE ALFA GODS BLESS YOU :D
Drive'm Hard
