Oil Leak
Posted: Fri Jan 07, 2005 12:12 pm
Advice wanted please for an annoying oil leak on my GTV6
My V6 is leaking from the joint between the sump and the block, not between the flat part of the sump base and the sides, but where the vertical part of the two part sump bolts to the base of the block. The leak is worst at the back near the flywheel where it seeps down the back onto the sump fins and forward motion of the car blows drips of oil back to the exhaust downpipes. messy & smelly when hot.
Looks like an absolute bitch to change that gasket with the motor in the car. Has anyone removed the whole sump without removing the motor from the car? I dont mind dropping the exhausts etc to get access, but don't want to have to take the whole thing out just to change a gasket. I've tried tightening the bolts up cautiously, but didn't stop the leak.
Hope I can do this with it in the car ! comments please
