Head Gasket Replacement Issues!!!
Posted: Tue Jul 25, 2006 3:43 am
I hope someone can help me here, because I am at a complete loss.
I finally decided I've had enough with the water leaks around the heads and decided to go ahead and replace both head gaskets.
Before I proceeded, I checked the timing alignment and noted that the P mark on the crankshaft was perfectly aligned with the pointer and both crankshaft marks were also aligned perfectly.
I removed and cleaned the base of the heads and the block as well, being careful to provide a clean mating surface for the new head gaskets.
The old mulitpiece gaskets were replaced by the single one piece gasket. I was careful to remove liner sealing rings.
So I button it all down, torque the head according to spec. and replace the timing belt. Everthing perfectly aligned as before. Do a compression test and WTH??? 35 psi on cylinder 1 and 2, 120 psi on cylinder 4 60 psi on 5. I stopped there. Where did I go wrong?? Before the replacement all cylinders were between 175 - 190. My first reaction was "You dumbass you messed up the timing", but I rechecked and everything lines up.
The dealer who sold me the head gaskets assured me it is the correct type for the 2.5 V6. Have I missed something?
Any help, ideas or other corresponding idiocy checks would be greatly appreciated. I have no ideal what I have done wrong.
Marco
Marco
