TS Flywheel on V6??
Posted: Wed Nov 29, 2006 11:39 am
by sira
Does TS Flywheel and rear engine mount fit on V6 engine???
Posted: Wed Nov 29, 2006 1:07 pm
by TS_turbo
no way ... v6 is externaly balanced AFAIK ...
Posted: Thu Nov 30, 2006 12:54 am
by Daniel
No to both.
V6 flywheel is definitely a balanced one and rear engine mount doesn't even go close, waayyy different bolt pattern.
Posted: Thu Nov 30, 2006 1:33 am
by TS_turbo
Daniel are you sure V6 is zero balanced? as far as i know v6 engines are not naturaly balanced ... and have seen v6 front puleys-> not zero balanced-> sign of external balanced crankshaft external balanced cranks have ofset weighted front puly and flywheel
Posted: Thu Nov 30, 2006 2:52 am
by Micke
The V6 has counterweights both on the front pulley and flywheel. 4-banger has neither.
Posted: Thu Nov 30, 2006 2:58 am
...and vibrates like it too. :D
Posted: Fri Dec 01, 2006 1:04 am
by Daniel
Yep, that's what I'm saying - the V6 flywheel is part of the crank balance. It has a section cut away for about 2/3 diameter on both front pulley and flywheel. Engine don't run so good without it.
