pancho
24v Cylinder Head Gasket Kit - Where to buy
Post by pancho »
Ok Well my 24v project is undrway again - next step is to buy a complete Cylinder head gasket kit and engine gasket kit - which apparently includes the oil valve stem seals as well.
Part numbers are 71713723 Cyl and 71713724 eng.
Can anyone advise where would be the cheapest place to source these kits from, Alfa australia thinks they are made of gold or something and prices them accordingly.
PanchoRama
Sporttunergtv6
Post by Sporttunergtv6 »
I think that IAP sells them. Just punch in a 1995 quad cam 164 as your car. I think they are even oin sale.
vittorio
P,Im bringing in stuff from EB Spares in the U.K.
40% cheaper than here..chat to Kevin. :D
pancho
Post by pancho »
thanks sportuner, its a 166 3L though. Not sure if there are differences, but there would some minimal ones for sure.
Thanks, B. I will see if I can catch him on here, or if you would be kind enuf to send me his email addy.
PanchoRama
pancho wrote:thanks sportuner, its a 166 3L though. Not sure if there are differences, but there would some minimal ones for sure.
Sorry mate,was a bit vague here..Kevin at EB Spares in the UK..
admin@ebspares.co.uk
Bb
pancho
Post by pancho »
Ah yes, now I understand.
He says he has aftermarket complete engine kits available for 150 pounds but no original alfa kits in stock. Is original better than aftermarket ?
What would you do Barry ? :?:
Go original or aftermarket ?
PanchoRama
Id get 2x REINZ headgaskets ..All the others can either be reused(cam cover rubber seals and plug seals)or gray Loctite siliconed..(water pump and thermo housings,etc..)
If the rubber plug seals are hard,get those as well..
Btw,REINZ is OE here..
If your using 164 type cam covers,chances are the old 4 piece gaskets are shot as well..Get those as well then.Your 166 based?Its got the newer ,better runbber sealss.. :wink: :D
pancho
Post by pancho »
I got a whole engine kit for $390 aftermarket. Same brand as OEM, just without the logos.
Should arrive tomorrow. Thanks B. 8)
PanchoRama
pancho
Post by pancho »
Gaskets arrived Brand name Payen from belgium.
Anyone heard of them ?
PanchoRama
Payen is good quality...best available for MGB's. Fel-Pro here in the USA is owned by the same folks that own Payen and Fel- Pro gaskets are generally real good ones.
HTH
Scott
bteoh
Post by bteoh »
Pancho, did you get them from Turin Imports?
pancho
Post by pancho »
Hi Brian,
yes I did. SUPER fast shipping.
Thanks Scott.
Its a Federal Mogul Owned company I believe.
PanchoRama
Pancho,
Federal - Mogul sounds right....couldnt think of it last night. Not that there is a problem with Reinz....there isn't (except they are bloody expensive usually) but the Payen should be good.
Scott
pancho
Post by pancho »
expensive maybe but not OEM expensive !
engine gasket kit 181 pounds
head gasket set 166 pounds !
so AU it would have been over $880Au
I got my full engine set for just under $400 and they were in stock - so I am very happy.
Thanks for the help guys. :D
PanchoRama
Burger
Post by Burger »
Pancho,I was wondering if those gaskets are the "metal sandwich" kind or like the one piece 2.5 kind?
