Page 1 of 2
Autronic
Posted: Fri Feb 11, 2005 3:10 pm
by Zamani
Jarle, we can discuss the system here.
Posted: Sat Feb 12, 2005 9:22 am
by Jarle
Hey Zamani.
Did you feel any power increase,just switching to Autronic.
Are you using the distibutor?
I have really not got to test the system properly yet. You said you have not fine tuned the system.... Does this mean that you have not ran the Autotune function yet?
Have you tested the launch controll? I know the transaksel cars dont really like this thogh..... We compete in something called "street legal" her that means first man from 0-201m.
Jarle
Posted: Tue Feb 15, 2005 9:09 pm
by pancho
I have an SM2 that I am putting onto the 24v project, just got a new loom ordered AU$250 !!!
Posted: Wed Feb 16, 2005 10:43 am
by Zamani
Pancho,
Fitting Autronic in a 24V is much easier. You already have the cam sensor. On my car I am using the hall effect sensor (as the home sensor) in the dissy and a flywheel sensor.
Why did you go with SM2? A friend in Singapore uses SM2 for his 164S Turbo, but that's because his FWD is a handful and launch control (or was it traction control?) useful.
Jarle,
How is your autronic setup? It looks like you are running wasted spark? That means you cannot use the over-no-1-plug sensor as the "home" sensor.
Posted: Wed Feb 16, 2005 3:00 pm
by Jarle
Yes I am using wasted spark with a Bosch T6 ignition coil. Use a cranktrigger that gets 3 signals for each 360crank degrees.
Jarle
Posted: Wed Feb 16, 2005 3:04 pm
by pancho
Zamani,
I bought it off Julian ! He parted the 164 and now has a Volvo
Posted: Wed Feb 16, 2005 4:05 pm
by Zamani
Aha! You must have bought it for a song. Wiring harness all done. Damn good deal I think.
I'm going to buy something from him. Actually I bought all sort of stuff from Julian in Singapore (not our Jules in Sydney of course).
Jarle,
Don't you need a signal for cyl. 1? How are you getting that signal? Are you still using the no-1 plug signal and divide it by 2? My marker pins are on the flywheel as per Joe Beninca's recommendation. In fact I have all the tooling for putting pins in the flywheel (thanks to Joe Beninca).
Posted: Wed Feb 16, 2005 7:02 pm
by pancho
Yep got it for a very good price, I havent powered it up yet so i dont even know if it works, maybe this weekend I will get a chance.
The harness I dont think I will need or want, I will be getting a new one this week and starting from scratch, no point in finding gremlins later on.
Posted: Thu Feb 17, 2005 2:37 pm
by Jarle
Zamani: Yes I have a sylinder reference trigger. Its mounted behind left camgear. I have welded a bolt into the camgear and the bolt passes the sensor when syl 1 is at TDC.
Jarle
Posted: Thu Feb 17, 2005 2:40 pm
by Jarle
Bad position, but I think you seen how it works.
Jarle
Posted: Thu Feb 17, 2005 5:23 pm
by Zamani
Ah ok Jarle that looks good!
I thought the dissy was a simple method so I used that instead.
Actually, I think SMC 1.92 can accept 60-2. So you can just use an SZ or 75 3.0 Motronic crank pulley and crank angle sensor.
Posted: Thu Feb 17, 2005 10:34 pm
by Jarle
I have the 1.92version, and the engine comes with the motronic engine management, but MRM-Racing adviced me to not use the standard 60-2 pulley. (Did not actually ask them why...)
Jarle
Posted: Mon Feb 21, 2005 2:06 pm
by Jarle
Zamani: What kind of idle valve do you use?
Jarle
Posted: Mon Feb 21, 2005 6:56 pm
by Zamani
Jarle,
Just the standard GTV6/75 bypass valve setup.
Posted: Tue Feb 22, 2005 3:03 am
by Jarle
Hi Zamani.'
Ok, have some trouble with my idle. I guess you use the aux output to controll the idle valve. Could you check on your olde mods setup, what number do you use on olde mode 5=?
Olde mode 5=0 The aux is set to use a bosch 2 lead idle engine.
Olde mode 5=1 The aux is set to use a "ford/autronic" idle engine.
I have set mine to Olde mode 5=0, but I dont get the idle valve to respond respond to the system.
Would really like to see your cal file.
Jarle
