Page 7 of 11
Posted: Fri Nov 09, 2007 4:58 pm
by x-rad
good news, Scott!! :D :D
Hopefully, i will have some soon too!
Posted: Sun Nov 11, 2007 12:08 pm
by x-rad
Now i'm pissed...It seems that I did not phase the rotor wrong...If I had looked more closely...I would have noticed that the dog teeth (which are slightly eccentric) at the bottom of the rotor shaft were pinned 180 degress differently on my two different rotors!!!
Started Frankenstein junior transplant today as I have checked every wire and connection and can't find the problem...
I went out for a ride and got about 5 miles from my house when a big puff of grey white smoke came out the ass of the alfa...
I limped back home and started the engine transplant. At least if the new engine runs badly..the problem will probably be wiring and I will tear out the old harness and rewire everything....
Posted: Sun Nov 11, 2007 12:23 pm
by kevin
I found another suspect last week on a friends car on the fuel relay power supply. It was intermittent . Once you have installed new motor(if problem persists) connect a small globe into the red cable to the fuel relay.
Posted: Sun Nov 11, 2007 2:21 pm
by x-rad
Thanks, Kevin
I think it is electrical but just only happens with the right motion or vibration
Feul pump relay is new , but i will check the wiring as you say..
Posted: Sat Nov 17, 2007 12:01 pm
by x-rad
enigine went in fine today...
had a little trouble with the right headder once the starter was in....had to pull out Mr. 5 pounder...and then of course the flanges did not meet the head correctly...so out comes Mr 5 pounder again...and now all is well....
Doubled up on the headder wrap cause now the starter heat shield does not fit...
should be well protected....
Posted: Sat Nov 17, 2007 12:06 pm
by x-rad
more tips...
Posted: Sun Nov 18, 2007 4:58 pm
by x-rad
Ok...so apparently...you have to have the thermo time switch hooked up otherwise you flood the engine for 30 minutes...
once thermotime switch hooked up, engine fired right up!!! :D :D :D
But, that was only after realizing that only two out of six injectors were firing...not because of bad wiring..these were a spare set I THOUGHT would work....but after sitting around for 15 yrs with no fuel, they were stuck shut
so my set of brand new injectors went in and man, this engine just revs away...
settled the driveshaft in and will tighten everything up tomorrow
it was a good day in the shop topped of with a nice rotisserie chicken my wife cooked up on the grill..mmmmmm :D :D
Posted: Mon Nov 19, 2007 12:50 pm
by x-rad
broke her in today...wife was jussssst a little upset about the header wrap smoke...
ran great, but i still have a power surge back and forth, in other words, engine will not hold rpm steady at any rpm level..
don't have idle as low as i want but that will come.
Oil pressure excellent at about 75lb to start, now down to 55-66 at 2500rpm
No leaks. Heat shield was rubbing shifter but bent easily out of the way..
They don't have inspections in this state so no cats...man it sounds like steel bearing ripping around a steal drum when you rev it...(not in a bad way)
No smoke, no antifreeze out the ass pipe...which is good
road max cams and 10.5-1 comp pistons are pretty steady at low rpms...but just touch the throttle and whooosh
Forged alloy piston don't knock at all...
And the 90 amp alternator makes the lights all real BRIGHT..and no more 'alt' light at low rpms
I do need to get a new heavy duty high amp battery though...my old one is original to the car (which means 5yrs+) and it is kinda low power to begin with...
Posted: Mon Nov 19, 2007 2:00 pm
by grant
Video please...
I'm very jealous of your budjet rebuild. I think I'm going to have to pay list price for everything when I rebuild.
Posted: Mon Nov 19, 2007 3:39 pm
by x-rad
Grant: if you forget the carillo(or equal) rods and the C/B cams..you can save a huge amount...for the parts and for the head labor, too.
will try to get some audio/vid up tomorrow
audio/video
Posted: Tue Nov 20, 2007 3:04 pm
by x-rad
AUDIO/VIDEO TIME:
got some real short vids of ass end with some good sound....wife as not really pleased to rev the engine...but she did it...and i am happy :D
not revved over 4G yet..but sounds awsome...can idle at 800 rpm at the lowest..whole car kinda rocks side to side..
sounds like a top fuel dragster ..minus 2 cylinders and 10,000hp..
Idle: http://www.youtube.com/watch?v=Fptp59qQHEs
Rev: http://www.youtube.com/watch?v=bvPQ1ZCNOgM
Posted: Wed Nov 21, 2007 12:36 pm
:D
Job well done.
Posted: Wed Nov 21, 2007 3:16 pm
by Rookie ROX
Sounds great! I bet you can't wait to get it on the road!
ROCK ON
R~R
Posted: Fri Nov 23, 2007 4:36 pm
by x-rad
thanks guys!!
this weekend..road test...
Posted: Fri Nov 23, 2007 7:15 pm
by ar4me
Congrats with successful surgery! Video test drive.
