Page 1 of 2
groove on my 12v 3.0 crank journal
Posted: Fri Sep 21, 2007 1:14 pm
by zambon
I just took the pistons out of my 3.0 verde engine and I was disapointed to see a groove on the journal for cyl number 4.
What are my options? I would like to keep my three liters, so I am not very interested in installing a 2.5 crank. Can I use a 164 crank? What complications would go with that?
thanks,
James
Posted: Fri Sep 21, 2007 3:02 pm
by x-rad
of course..how bad is it (how deep)??? 2.5 crank won't work as journal centers are different.
grind it 01..02..etc??? IAP sells the bearings for 50$
Posted: Fri Sep 21, 2007 5:02 pm
by zambon
Thanks for the reply,
I didnt realize that undersized bearings were available. This is a rod bearing, and IAP has .010 over. I will take it in to a machinist this week and see if that will be enough to remove my defect.
Posted: Fri Sep 21, 2007 9:01 pm
by Barry
x-rad wrote:of course..how bad is it (how deep)??? 2.5 crank won't work as journal centers are different.
No,they're not..stroke is different if thats what you mean but a 30l and 2.5 crank is interchangeable..
James,if the journal needs to go more than 0.30" I posted a list of Mercedes bearing that could be used instead.. 8)
Posted: Fri Sep 21, 2007 9:02 pm
by Barry
Posted: Sat Sep 22, 2007 7:19 am
by zambon
Thanks Barry,
This is a deep groove and it would definitely require more than the 10 over bearing that IAP has for the rod journals.
Could you tell me where to find your list? My search attempts were fruitless.
Posted: Sat Sep 22, 2007 11:24 am
by x-rad
meant "journal to pin centers are different"
...it will fit... but you can't just exchange without other mods
Posted: Sat Sep 22, 2007 2:48 pm
by zambon
I had a mechanic friend look at it today and he said that it looked like a factory oil groove. He reasoned that it is too big a groove to appear on its own. He said that he had seen similar grooves on engines that threw rods, but that isnt the case here. The groove is smooth and there is no blueing around it to indicate that it may have been getting hot.
I dont know what to think, I guess I need to get a photo up here.
Posted: Sat Sep 22, 2007 2:54 pm
by x-rad
post a pic!!!
.....often there are manufactured oil grooves extending from the oil hole in the crank on the mains. these are longer along the counterclockwise direction for a crank that rotates clockwise. They taper evenly. Also, should be no corresponding bearing wear.
Honestly, I just put my crank in two weeks ago and I don't remember if there were grooves or not....If there were, i thought they were oil grooves as the bearings were nearly perfect...
Posted: Sat Sep 22, 2007 5:05 pm
by zambon
This groove is only on the journal for cyl #4. That is the first rod journal. I will see if I can post a picture later.
Posted: Sat Sep 22, 2007 6:38 pm
by zambon
photos....
Posted: Sat Sep 22, 2007 6:44 pm
by zambon
As you can see (sort of), the bearings for this rod are in good condition. No discoloration to speak of, no obvious wear on the bearings or the journal.
The groove is longer in the counterclockwise direction.
Posted: Sat Sep 22, 2007 7:28 pm
by Zamani
Ermm... I think this issue was brought up before by one of the members a while ago. This groove is from the factory I think.
Posted: Sun Sep 23, 2007 12:32 am
by Barry
*smile....*....yea James,its made like that..Thats std. from the factory..dont worry about it..
Posted: Sun Sep 23, 2007 8:02 am
by zambon
Thanks guys, I am very glad to know that it is ok and I can get on with things.
