An interesting way to set up a 24v's inlet manifolds.
What do you guys reckon, worth it or not?
- Rookie ROX
I'd say it's all show and no go.
Looks like the perfect way to destroy the flow in the inlet, way too much area per cylinder and/or too short runners, depending on how you see it.
- Rookie ROX
I think it looks fantastic. I sort of doubt there is any performance benefit, but that's tough to say. Airflow is not very predictable, and sometimes weird experiments work out pretty well. It would be interesting to put in on a dyno and see.
P.S. the biggest problem I see there is the lack of red silicone vacuum and coolant bottle hoses. Red plenum couplers would be great to, but the 164 couplers are not available in silicone because they are so small on one end. (the runner end is about 39mm on a 24 valve 3.0, way smaller than on a 12 valve 2.5...what's up with that?)
- Rookie ROX
