Broken timing belt
Posted: Sun Feb 08, 2009 9:13 am
This was a seriously close call. My wife has been driving my GTV6 and she told me the car was making a funny noise. I started the engine and saw what I thought was maybe a mouse stuck to the timing belt.
Once I tore it down, it was no mouse. So I got to spend yesterday doing the timing belt thing. New belt, water pump, spark plugs / well seals, belts, valve cover seals, and had the radiator rodded. All in all about $450 in parts.
But that's a whole lot cheaper than bent valves. I think the main crank gear skipped a tooth, since both cams were timed together, but were out of time by one tooth to the crank.
I posted some pic's, what an odd break in the belt.
I know there are some people out there who don't use timing belt covers, but I do. So it wasn't a case of no cover and something damaged the belt. This belt and pump had only 3 years and maybe 15,000 miles on it at the most since I did them last too. The pump looked great, and probably didn't need replacing.
One thing that I HIGHLY recommend is the use of anti seize on every bolt that is used for the water pump, including the thermostat housing. When I did my pump 3 years ago, I encountered 4 broken bolts. I fixed them all and used anti seize when replacing. It made the water pump R&R a breeze, with no broken bolts.
I was going to retorque the heads too, but the bolts were so tight I didn't want to loosen them. It was over 100 ft lbs to loosen them, and the torques setting was supposed to be 75 ft lbs. I don't have a problem, so I didn't want to create one.
It runs perfect again. No apparent damage done.
