Cam belt change
Hey all. My water pump packed in yesterday,
and I have to change it fast tommorow. I dont have access to a timing gun or the tools I normally would have to change the cam belt where I am, and I dont have the time to take the cam covers off either. I have about 4 hours to do it all tommorow. My intention is to cheat, by removing the belt cover and locking out the cam sprockets with two ring wrenches locked together using beefy grips. I will also mark the pulleys in relation to the heads, along with marking the front crank pulley. Then remove the belt, and change the water pump. I haven't changed the cam belt using this "iffy" cheat method before, but have no choice where the car is at the moment. Any one else changed the timing belt this way before??
Re: Cam belt change
Make sure the crank position, and distributor position are also marked. Use lots of marker/white out/liquid paper to mark those positions. It's possible to do it with lots of mark on the various pulleys and block.
Re: Cam belt change
I would still put crank at TDC, cams at marks, etc. Even if you don't have your 41 mm socket to turn the crank this is doable by putting the car in a high'ish gear and push it to turn the engine over. This way if something does go wrong you are in a well-known position, making it easy to recover. If you have computer access, which it seems you do, you can print the cam template, and you have all the reference points (even if your cam covers don't have the cam marks). The template seems more accurate anyway.
Re: Cam belt change
good point Jes, I will rotate her to TDC to start, before locking the cams out (will have to dig out car disk, can't remember what TDC is on the 2.5 euro crank? if memory serves me right it's T mark?????, anyway no big deal, I'll look it up). Mine has the early cam covers with no marks unfortunately
. wheres the cam template at to download?
Re: Cam belt change
'P' as in punto
Re: Cam belt change
I don't recall the URL. It was created by a 164 alfista. I have a pdf version stored I can email if you PM me your email address. It will not let me attach the pdf file here...mjr wrote:wheres the cam template at to download?
Re: Cam belt change
cheers mats, jes I'll mail ya
Re: Cam belt change
by the way, here is the cheecky monkey!!!
Re: Cam belt change
Is that the anthracite color? One of my favorits for both GTV6 and 75/Milano. BTW, emailed you the template.mjr wrote:by the way, here is the cheecky monkey!!!![]()
Re: Cam belt change
jes, received, many thanks, appreciated. yes its factory "Nero 909", slightly lighter than anthracite, though it seems darker in the picture.
Re: Cam belt change
4 hours!!, I am in the process of doing the water pump and cam belt and I have done the belt on a 164 before, but this is something else. The manual is vague, trying to locate the lower tensioner bolt took 2hrs as it is hidden behind the spring and no where does it say release the spring. Everything has to come out, inc radiater and bonnet. What a nightmare.14 hours i may be lucky! anyone who has not done it before and does it in 4 hours is a genius. It took me ages to get the coolant plugs out to flush the coolant alone. you need the hands of a child and the strength of strong fit man to do these jobs as well as the skills of a circus contortionist to do this job, I bet you were late for your appointment.
