Engine cuts out some of the time at 5200rpm
My 1983GTV 6 engine revs out with ease but occasionally cuts out at 5200rpm, as if the rev limiter has been hit, I have replaced, leads, coil, rotor button, distribotor cap, plugs, and checked everything, could it be the ignition module? any ideas appreciated.
Re: Engine cuts out some of the time at 5200rpm
Oil in the plug wells?
Engine ground straps?
Is the fuel pump up to the job still?
Yesterday when it hit 5200 and cut out there was a loud bang in the exhaust so I am figuring the backfire is ignition. The car runs like a gem until 5200rpm and maybe only 1 out of 3 times cuts out and missfires at 5200rpm.
I haven't checked the fuel pressure - any suggestions on what sort of gear I would need to check the pressure?
Thanks.
Thanks.
Loud bang is definately ignition. Whats the ditributor bearings like
Thanks, I will check. Everything is earthed, no oil in plug wells.
