hi all, i have a 1982 gtv with a 1985 90 2.5L v6 in it.
for the most part the engine runs well,
however lately sometimes on start up or running the car will cut out, when i try to restart it, it will start then immidatly die,
ive cheaked all coil wires, sometimes when i cheak spark it will be dim then all of a sudden bright, ive cheaked the theermo sensor and i know that the double relay is working as inhave manually connected the pints to make sure the fuel pump wurls as well as when the AFS gate is opened. i also know the air intake is leak free. i dont no why and im really at my wits end with the car. any help would be gratly appreciated thanx
Re: 1982 gtv6 starts but wont run, PLEASE HELP!
sounds like injectors quitting (all except the cold start injector)...that means an electrical issue or blocked fuel system. I go with more likely choice...Check all engine grounds and all connections.
OR
of course, you are losing spark only after starting, which may be a distributer issue...but less likely.
try a switch out of your ecu with a good working one?
OR
