Engine Stand
Posted: Tue Nov 27, 2012 7:31 pm
by mmelton
Where can I find an engine stand that will safely and reliably hold the GTV6? I see them advertised for small block Chevys, but I doubt that's going to do the trick. Who's got engine stands (cradles) for us, and what, exactly do I ask for?
Re: Engine Stand
Posted: Wed Nov 28, 2012 1:43 am
If it will hold the Chev motor it will hold the Alfa one .
Re: Engine Stand
Posted: Wed Nov 28, 2012 1:48 am
by Murray
Mel I have had perfect results using cheap generic type as seen in the image.You have to find the appropriate bolts with the correct length and/or adjust using washers to make sure your attachment points are solid and don't bottom out in the block's holes.I choose to keep a wooden brace under the motor when not rotating to reduce stress.
Re: Engine Stand
Posted: Wed Nov 28, 2012 10:00 am
by mmelton
Many thanks, guys.
And Murray, that's one beautiful motor.
