Bruce
GTV6 cams in 3 litre 75QV
Post by Bruce »
.. has anyone tried these cams in said engine?
Re: GTV6 cams in 3 litre 75QV
Should fit but is a serious step back... :?
Bruce
Post by Bruce »
... how do they compare to standard 3 litre cams?
GTV27
Post by GTV27 »
The specs that I have on file:
GTV6 Standard
intake 222@0.05, 9.1mm lift
exhaust 205@0.05, 8.9mm lift
3.0 Jetronic
intake 226@0.05, 9.7mm lift
exhaust 206@0.05, 9.2mm lift
3.0 Motronic
intake 230@0.05, 9.2mm lift
exhaust 214@0.05, 9.2mm lift
Motronic is the best option here. SZ cams may be different/better, but I don't have specs on them handy.
For the record, mine has the following, which are very similar to the fabled 10548s used to great effect in the 2.0 Nord:
Intake 234@0.05, 10.3mm
Exhaust 224@0.05, 10mm
This may not pass smog wherever you are, but makes for a fabulously torquey engine that will sing to whatever rpm you care to set your rev limiter to (mine is 6.5 as I am pretty conservative and that's fast enough).
Jason
1983 GTV6 2.8 litre
This subject has been disputed several times, here and on the BB. 3liter Motronic cams are identical to SZ cams; they have the same part numbers, 60548163 and 60548164. These cams are used in the late 164, 75 and SZ/RZ.
GTV27
Post by GTV27 »
thanks Jim - I shall update my records!
Jason
1983 GTV6 2.8 litre
shiny_car
Post by shiny_car »
GTV27 wrote:3.0 Motronic
I believe it is 10.1/10.1.
Motronic cams:
IN: 230*@0.05", 10.4mm CAM lift.
EX: 226* @0.05", 6.54mm CAM lift (9.16mm at valve with no clearance)
shiny_car
Post by shiny_car »
It is true that I can't read specs when half asleep! :P 10.1/6.4 according to this:
http://www.international-auto.com/file_ ... /index.cfm
Jim, perhaps your specs are actual 'measured' specs you've done? The above may be factory specs. :?:
Either way, I'll go with yours - I won't even pretend to know what I'm talking about in comparison!
