24V => 12V crankshaft interchangability
Posted: Tue Jan 27, 2015 10:03 am
by PietereQ
A friend in his 75 3.0 12V track car needs a new crankshaft. Since our shaft cannot be grinded, and availability of nos shafts is null, question is will 24v crankshaft fit in 12V? I know there are some dimensional differences around flywhell flange area what about the rest?
Re: 24V => 12V crankshaft interchangability
Posted: Tue Jan 27, 2015 10:08 am
by Giuliettaevo2
164 style 24v crank will work. Later style is different due to oil pump drive.
Posted: Wed Jan 28, 2015 4:03 am
by PietereQ
Thanks Remco!
Posted: Wed Jan 28, 2015 5:50 am
by Jim K
You can also use a later crank like the 3.2 if you machine off the teeth for the oil pump drive. The rear flange where the flywheel fits is as the 3liter.
