Hi everyone, just curious if anyone happens to know the weight of the assembled Pistons (rings and pins included) from a 2.5 24v engine from a 156. Or may have lying around that they could weigh for me.
Ben
Re: 2.5 24v pistons
Post this question on Alfaowner in the 156 section, you should get more hits.
Re: 2.5 24v pistons
Thanks 75evo, I posted it there as well the other day. Hopefully someone can help out
Ben
Ben
Re: 2.5 24v pistons
569.9gr complete.
Re: 2.5 24v pistons
Thanks Jim K, much appreciated!
Ben
Ben
Re: 2.5 24v pistons
This is the piston I have here. Chances are different runs will vary ±2 or more grams. To dynamically balance a specific engine you need the exact component weights of that engine, otherwise you'll be way off.
