Cam Pulley Tools
Posted: Tue May 17, 2005 8:43 am
Just a quick thread for reference as I've just spent ages searching out other threads for pictures of tools and techniques for removing, timing and refitting the cam pulleys. (I need to change the cam oil seals and then make sure the timing is spot on afterwards)
Tool to lock the cams together if you need to can be seen here:
http://alfa.denovich.org/twiki/bin/view ... ulleyTools
Tool to remove retaining cap & home made "adjuster" :
http://www.alfapower.nu/gallery/album416/abk
Picture of cams showing slotted retainer pulleys for exact adjustment if necessary:
http://www.alfapower.nu/gallery/album416/abi
Also heard that many Alfa racers simply remove the cam locking "key" and rely on the morse taper at the end of each camshaft being robust enough when the retaining bolt is tightened up to work perfectly well and be infinitely adjustable. As the factory morse taper plus key is a "belt and braces" option I'll probably stick with it and file the holes if I need fine adjustment.
All credit given where due to those who made and posted the photo's of the tools. I'm only posting this to make is easier to find for anyone in future - especially me !
