grega
rubber donut for idle
Post by grega »
Help please
Hey guys. I removed the rubber donut that sits between the idle adjustment double nut. And It fell sowhere in the engine.
I'm afraid it's lost for good. Does anyone know where i can get another one?
Greg A
SamW
Post by SamW »
IAP should have them, I don't see them on the website, but give them a call.
http://www.international-auto.com/
Alfa GTV6 NZ
Post by Alfa GTV6 NZ »
Is it the one between the plenum and the double nut adjuster?
If so then any correct sized rubber o-ring should do the trick.
The trick with this is when you tighten the adjuster it squashes the o-ring and makes the hole smaller, and so lets less air pass. I'm guessing you all knew that.
I replace mine every once and a while as they can get out of shape or loose their squishyness.
grega
Post by grega »
alfa gtv6 Nz
yes that's the one!
Sam thanks for the response!
Romeo69
Re: rubber donut for idle
Post by Romeo69 »
Hi all,
does anyone have the thickness and the exact size of this donut? Mine has already shrinked and it is difficult to see the right size. I already tried a few ones, but none of them worked well, idle was always difficult to set.
Or does one know where to get them? (other than international-auto)
Thx
pat
grega
Post by grega »
Hey pat,
luck for you i made a note of the size before i installed.
I purchased it from I.A.P.
I.D. 5.84mm
O.D 12.70mm
Thickness 3.42mm
Romeo69
Post by Romeo69 »
Thanks Greg! For anyone else searching them: at IAP they are item #16991.
Regards, pat
Boazdexter
Post by Boazdexter »
hello
this is Dexter
and i want to know something good about this topic
and it would be good reply ok
_______________
"Want to get-on Google's first page and loads of traffic to your website? Hire a SEO Specialist from Ocean Groups seo pecialist
