REBUILD
Posted: Tue Nov 08, 2005 3:20 pm
My mechanic has finally finished rebuilding my car to standard specs. The following work has been carried out so far:
Engine: Many new parts following Murrays shopping list. My mechanic refused to fit Total Seal rings ( by the way I am seling the set for a resonable price). preferred to fit new standard pistons and rings , he believes total Seal rings will wear to engine out in the long run. Have fitted a new hidraulic Tensioner. I would appreciate your comments.
Transmission and suspension: New Rubber Couplings, yellow Koni's , ball joints and poly bushes throughout. Haven't changed the springs. My car is european spec. Can I lower the front leaving the rear springs and how far should I go? Anythis else to be considered before I take the car from the work shop?
I have fitted a new exhaust and repaired the airconditioner as well.I will be soon repairing several rust spots and having a full body respray (but not down to bear metal).
All parts supplied by EB Spares and Highwood Motors in the UK.Great help.
I might keep standard 15" wheels, fitted with 195/60 tyres. Any point in changing to 205/55/15. ? Will this improve performance or handling?
Can I fit the following allow wheels: 2x17"8,5 x 17" ET20 and 2 x 17" ET19- 5x112 ( i do not know what the last bit means). They are OZ racing and look great but i do not know if they will fit.
I will be posting picks as soon as bodywork is completed.
Regards
Regards
