cam timing question
Posted: Wed Nov 09, 2005 8:13 pm
I recently purchased an 82' gtv6 w/ 3.0 liter engine. I have it torn down right now to do timing belt, adjust valves, etc. My question is this. When I bring the engine to TDC on #1 cylinder my left cam lines up perfectly w/ the factory indices. My right cam (intake side) however the marks are about 1/8 '' off. What gives? Is this normal? My manual says they should both line up @ TDC. The weird part is the engine ran strong right up to me taking it apart the other night. I also havent removed the timing belt yet. Do you think Its a tooth off? Should I line it back up?
Second question. I have the mechanical tensioner on the car. I know from reading posts that most people dont trust it. That being said I cant imagine retrofiting the hydraulic one at this point. Do I have to buy a new mechanical tensioner w/ each belt change? I've read that the springs give and break. Does this happen at a certain mileage interval? Finnally I saw the staybelt tensioner that alfa heaven makes. I realize that belt wear may be a little more and it has no provision for block expansion (which I cant see being a major factor) does anyone here use this product? If so for how long has it been installed? Any other pros or cons to it?
Thanks in advance for everyones help. This forum is awsome for tech help and honest opinions. It has been invaluble to me in researching and buying my new pride and joy.
