The leads are Bougicord from here..theyre resistor leads...You dont want to run a resistor plug with them.
Any plug with an "R" in the number is a resistor plug.Swap them out for an
NGK BP6ES...NOT BPR....
Stick them in and take the car and give it an "Elaborato!!"Thats an Italian tune up..drive the crap out of it..within reason of course..Good 200km/h run for a minute or two..or three ...Full revs through the gears...make the engine work.
Check the plugs again..If theyre still oily and gunged up you have a problem..
How have you run the engine in??pussy footing all over or have you given it stick??
Perhaps we should take this off forum and e-mail...
![Question :?:](./images/smilies/icon_question.gif)
