Hi,
Just wondering if anyone is using the optional output (blue/black wire) on their MFI-Pro to switch on the fuel pump. I am looking at how to wire up the relay for the fuel pump. Tried to message GoTech but have not had any response so far. Should there be a voltage reading from the blue/black wire? Would appreciate any help on this. Thanks
Thanks Sam,
That was what I was after. I still can't explain why the engine shuts off a few seconds after starting. The relay for previous AFM has been disconnected and separate relays used for fuel pump and ecu. Haven't tried changing the settings on F5, fuel pump output to -600. Not sure what the default setting is as I haven't got access to the car yet. Disappointed not to get any response from GoTech on this....
