Feels good to have an official home here on the TA for these sweet little units!
For 700 to 900 bucks (STandard or Pro) including a nice new wiring harness WITH brand new Alfa-style connectors to the injectors, engine temp, air temp sensor etc, you can't beat the simplicity of installing one of these and starting the car right up!
I will be bring about 5-6 more units back from South Africa with me in about 3 weeks...
- junglejustice
Aahhhhh... Thanks Michael!
I'm about to put a standard on my verde - waiting for new rubber sleeves and paper gaskets (since it is apart). But, it does appear pretty straightforward - we'll see if it fires right up. Only catch could be to adjust the timing one direction or the other with a fixed value (our starting points are different it seems). Also, I will be looking into putting it in closed loop with the O2-sensor once I have the basic setup running.
JJ, similar to megasquirt you need a thread with success stories - start with your own.
