Gotech Pro X
Merry Christmas to all,
I am using the original Alfa coil packs on my V6 Busso.Firing order 1-4-2-5-3-6
Does anyone know how I can check if this firing order is programmed in my Gotech Pro X.
Re: Gotech Pro X
I’m also running same ecu on my 24v . There are loads of base maps for that engine for tbe gotech pro x. Are you running cam angle sensor ?
Re: Gotech Pro X
Hi Kevin,
No ,I was told I don't need to,it runs 3 ignition batch phases under mode 4.
I have just wired it up and when I try to start the engine it back fires and won't start.
Do you know how the firing order is programmed .
Firing order on the Busso
1-4-2-5-3-6
1-4-2-5-3-6
Re: Gotech Pro X
Firing order is all pre programmed. I’m not running can angle sensors either . I think you’re on throttle bodies your map will be different to mine . This will start your car
- 1337CBB9-52C4-4ADC-BE47-CBB91DAFEA09.jpeg (85.68 KiB) Viewed 1884 times
- 0C95135B-0ED3-4C85-8894-D6FCDDDD925D.jpeg (116.06 KiB) Viewed 1884 times
- 43E2FD05-677B-466B-92C3-893A122EFB8B.jpeg (122.58 KiB) Viewed 1884 times
Re: Gotech Pro X
Hi Kevin,
These are my settings ,
My TPS is now 4.9
Can you see any of my settings that are inc and won't let my engine start?
My TPS is now 4.9
- IMG_E8026.jpg (100.82 KiB) Viewed 1880 times
- IMG_E8027.jpg (109.41 KiB) Viewed 1880 times
Re: Gotech Pro X
To change the setting is a bit hard , I need to Know which keys to press.
Re: Gotech Pro X
I downloaded the whole manual . Also there is a help menu once you’re switched on . I know a few guys who really good with this but they are on holiday at the moment .
See this link as it all should be here
https://powermods.co.za/Pages/Downloads.asp
Re: Gotech Pro X
Pages 1-5
- 5BF8DAA9-091B-44D9-9CED-8A4B46B63BDF.jpeg (86.9 KiB) Viewed 1864 times
- E2E607D4-F1D9-4B4F-8F62-73BFF9F09C75.jpeg (83.1 KiB) Viewed 1864 times
- 7E4046C3-0A22-425E-A19F-6263F2907DAB.jpeg (98.47 KiB) Viewed 1864 times
- 30867E10-C3D3-432B-82C3-DFC51E73867A.jpeg (95.67 KiB) Viewed 1864 times
- 0F0DDA5D-9D7D-4460-9B49-46DCF074BF96.jpeg (103.55 KiB) Viewed 1864 times
Re: Gotech Pro X
Pages 6-10
- 4795034D-3B92-4264-9D2D-20A4E82DDE8D.jpeg (103.21 KiB) Viewed 1864 times
- F99CD30D-E017-41FC-B990-CADA33FB7E1B.jpeg (95.34 KiB) Viewed 1864 times
- DF31AD18-D738-406A-84D2-9A2CCD7C5C0C.jpeg (100.45 KiB) Viewed 1864 times
- BCDD94BA-6874-4D4B-8464-BE2E0EF94F26.jpeg (81.01 KiB) Viewed 1864 times
- 7E890353-03CA-4748-8372-7C384D4FE9BE.jpeg (95.7 KiB) Viewed 1864 times
Re: Gotech Pro X
Pages 11-15
- 0DCE7F9A-DF73-490E-9AFA-22725081D5F4.jpeg (95.7 KiB) Viewed 1863 times
- 0CFDFFEA-F6F4-4ADC-80D2-B8A030BB57AE.jpeg (105.06 KiB) Viewed 1863 times
- ABCAF911-C184-4CA4-BA63-7AA8FCB9777A.jpeg (93.76 KiB) Viewed 1863 times
- 8BC63060-65E9-436F-A665-AAA698A2A934.jpeg (102.52 KiB) Viewed 1863 times
- FD0047F5-39BE-4BD3-BC66-4A78BE7B1628.jpeg (109.23 KiB) Viewed 1863 times
Re: Gotech Pro X
Pages 16-20
- 74F5ECDE-0F6D-485C-810D-0C028EAF23FE.jpeg (90.6 KiB) Viewed 1863 times
- B29F6939-62B0-4C11-9FA7-2ABA44184412.jpeg (89.29 KiB) Viewed 1863 times
- A463748F-1FEF-400D-B44D-85929A64EBCF.jpeg (98.56 KiB) Viewed 1863 times
- 77A0A46A-5A7D-4CD0-95E1-1DB08479A413.jpeg (91.85 KiB) Viewed 1863 times
- E969710C-20A9-4C83-AA2D-439AD1A36493.jpeg (75.39 KiB) Viewed 1863 times
Re: Gotech Pro X
Last pages
- 8D629932-BDD8-429B-875C-3B72368EA708.jpeg (103.62 KiB) Viewed 1863 times
- D51D69F8-DCEC-4305-9CD8-B214120828E3.jpeg (100.56 KiB) Viewed 1863 times
- BC7893E7-6066-45F8-8A7B-75AA39F5599B.jpeg (82.97 KiB) Viewed 1863 times
- C1681ADE-81E4-4AD2-B9F4-1A3956335BCF.jpeg (84.06 KiB) Viewed 1863 times
Re: Gotech Pro X
Hi Kevin,
Thank you for the manual its going to help. Fantastic
Would you have photos of your mapping for the fuel and ignition.EG refer photo attached
I have fuel at 55 PSI going to the injectors but when I crank the motor it seems the injectors are not spraying.
Electrical to the injectors are correct.
I think the programming mapping on the ECU is incorrect.
- Screen Shot 2022-12-28 at 8.05.27 am.png (125.96 KiB) Viewed 1838 times
Re: Gotech Pro X
Got the engine running ,
Just got to work out the idle on the Gotech Pro X ,
Will have to adjust the throttle positioning sensor.
Any advice would be great.
Re: Gotech Pro X
Hi Kevin.
Could you please show me your settings on your mapping graph on the fuel and ignition on your car ,
My snap shot shows 2.44MS and yours shows 0.17MS.
My engine is running so rich and its back firing at times.
I think my settings are too rich.
I cannot take the GTV to a dyno yet.
I just want to get the engine tune to an acceptable level so I can drive the car.
