Jes (AR4ME) asked me to give some info on my 75 track car. I am using it for a raceseries in Denmark called Club Race. Cars are categorized after weight and HP's.
Chassis fully re-welded from front to mid car.
Weight app. 990 kgs.
Dashboard, heater etc. removed.
All original electrical wires removed. New wires installed.
Autogauge tachometer, oil pressure, water temperature, oil temperature meter
Upper and lower front A-arms in steel tube.
Adjustable “knife” front anti-roll bar
Caster ball joints
Shankle anti-roll bar back
4,0 degree negative camber in front
1,2 degree negative camber back
Watt link upside down, ball joint connections
Centre dion axle uniball kit
Avo coilovers in front and back
Short steering rack, no servo
298 mm brake discs in front. 4 pot calibres from Porsche 944 Turbo
Vented and grooved Zagato discs back, calibres modified to fit discs
Homemade roll cage
Lexan windows
Hood lid in fibre glass
Trunk lid standard (lightened)
Front bumper in fibre glass
Back bumper in fibre glass
8x17 wheels w/ Dunlop slicks 235/610/R17
2 x 40 mm wheel spacers in front
2 x 25 mm wheel spacers in back
Small battery mounted right of driver
Sparco seat and belt
Engine:
2,0 T-Spark
AH Motorsport intake manifold
45 mm Throttle Bodies (unknown make)
Megasquirt engine management complete squirt and spark
50 mm custom made exhaust manifold
Close ratio gearbox (Colotti type) (2,57 – 1,94 – 1,55 – 1,22 – 1,00)
At 7000 rpm’s the speed will be as follows (theoretically):
1. gear 76 km/h
2. gear 101 km/h
3. gear 126 km/h
4. gear 160 km/h
5. gear 195 km/h
I drove last season with a standard engine (132 HP) and gearbox. Max. in the series I am participating in are 160 HP for a car with the weight 990 kgs. Above modified engine has not been started up yet, so HP etc. are unknown. Will update when known.
75 Race car from Denmark
- Dscn1038.jpg (127.65 KiB) Viewed 8948 times
- Dscn1046.jpg (157.15 KiB) Viewed 8948 times
- Dscn1055.jpg (124.4 KiB) Viewed 8948 times
- Dscn1057.jpg (132.27 KiB) Viewed 8946 times
- IMG_0165.JPG (23.99 KiB) Viewed 8945 times
Pics of upper and lower A-arms.
- Dscn0834.jpg (99.04 KiB) Viewed 8861 times
- Dscn0877.jpg (189.86 KiB) Viewed 8861 times
- Dscn0878.jpg (144.44 KiB) Viewed 8859 times
Henrik Valentin
Copenhagen, Denmark
1988 75 3,5 V6 12V racecar
1994 155 STW Nord Auto ex. Gherardo Gazzago (Under rebuilt)
1996 155 Q4 - Daily driver
Copenhagen, Denmark
Maurizio,
Here are 2. The car is equipped with a chip from Squadra in Holland. Makes 228 HP. Heavy car (1500 kgs) but great fun to drive.
http://www.youtube.com/watch?v=78GsEyWbef8
A little donut........from our trip to Holland in 2004.
- 155-1.JPG (218.38 KiB) Viewed 8852 times
- 155-2.JPG (156.69 KiB) Viewed 8852 times
Henrik Valentin
Copenhagen, Denmark
Copenhagen, Denmark
