apreciate
Oh I disagree with you...! A racing pump will cost 8 times more !!MD wrote:Easy. If you have an oil pump now, just recondition it with higher tolerances and get rid of the inlet screen. It's good for 80lbs which is more than enough.
A so called "racing" pump would be no different.
No experience in this one but completely get rid of the intake screen, gut feeling says wider mesh ok.MD wrote:Easy. If you have an oil pump now, just recondition it with higher tolerances and get rid of the inlet screen. It's good for 80lbs which is more than enough.
