Re: A new GTV6 2.5 entry into SA Marque car catergory
Glad you want to restore it to its former glory (3.0 Carb)!
Makes sense the way you are doing it.
I'll come cheer for you on the 28th.
Regards,
Niwou
Regards,
Niwou
Right...(TX, look forward to the race)... tomorrow is Scrutineering / compliance evaluation at Zwarkops so hope all goes ok... In the afternoon there is an open day, so will actually be doing the VERY first shake down laps with the car !!!!!.... if all is ok, then the next weekend is First race in new car...
A few more things now completed, the normal ignition,tow, etc, stickers, and bonnet catches fitted AND!!!!! THANKS to Kevin... the PROP is sorted!!!!!!!!!!!
See some "final" pics prior to roundels and race no going on during the weekend..
- did not realise that the gauges went RED after dark!!! - normally blue..
- photo32.JPG (89.99 KiB) Viewed 9385 times
- and from the "rear"
- photo31.JPG (117.1 KiB) Viewed 9385 times
- the cuplrit!!!it WAS the MIDDLE BEARING!!!!!!!!!!!!!!!!!!!
- photo 27.jpg (86.24 KiB) Viewed 9385 times
- front view.,...
- photo27.JPG (122.55 KiB) Viewed 9385 times
Yeah that dam prop . It was the locknuts just behind centre bearing . They were tight but not tightening up the yoke so was fraction of play . This only made a noise at very low rpm or when you switched car off . Had to put a small shim then retighten then feel for play by hand . The balance machine could never pick this up or simulate the noise aaaargghh .
Joe you might have to put rear toe arrow pointing down if they whine at scrutineering tomorrow .
Hope to see you there with my car on the track tomorrow .
Yesterday was the cars first race.... It was at the Zwartkops International Day.... PLENTY of cars, international and local...some pics below....
How did it go...Well, I was VERY happy (after we sorted the Brake problem), the fault being mine....!!!! I kept of getting a LOOOOOONNGGG pedal after 3-4 laps, and was obviously overheating EVERYTHING.... anyway to cut a long story short, the problem was that I "forgot" to chnage to proper racing pads!!!!! (yes....)
Lap times came down straight after Ferodo DS2500 were fitted (dear Kevin coming to the rescue at 05h30 the morning of the seond heat!!!!) - eventually won the second heat ...but I broke out of the class time!!!! so DQ!!!!
- 156?????
- picture45.JPG (151.06 KiB) Viewed 9327 times
- 75 Turbo!!!
- picture35.jpg (90.57 KiB) Viewed 9327 times
- Going through and PASSING scrutineering
- picture33.jpg (83.77 KiB) Viewed 9327 times
- NOW we can see them properly... Mine on the left, Kevin's on the right
- picture40.JPG (131.03 KiB) Viewed 9327 times
- Nice Cars ... Kevin the way again!!!!
- picture38.JPG (115.57 KiB) Viewed 9327 times
Nice car that Coloni 156...
Sounds quite as well.
I've seen the 156 and the 75 Tb in action over here in Holland on a few occasions and that was always very entertaining.
NOW i can't see a pair of GTV6's.... I just keep staring at them other beauties...
VERY NICE.....
VERY NICE.....
It was a great two days racing . Good to see joe driving the socks of that 2.5 . Three months ago we sat down and looked at costs of getting a v6 on the track and if it would be competitive within that budget . So the plan was to spend zero bucks on the motor and get the handling and set up spot on . Well budget was exceeded a"bit" but lap time was also exceeded by a second on first event . All in all been great project now it's up to Joe to take motor to next level again in a budget . This is where jims book comes in which we are all ready looking at cams and intake tubes . (don't want to take heads off at this stage). It also does help when you have a seasoned driver in a project who can push the car to the limit - probably why budget lap time was beaten .
From my side my 3.7 has done 56 hard laps and not used any oil(300ml) and gearbox is still together so all the hard work has paid off. I will put a summary on what has worked and kept my gearbox together on other thread . Also interesting to see time difference between my 3.7 and Joes car was 6 seconds and which was 7 seconds between me and the Coloni driven by Jan Lammers . Must say the 3.7 really makes up for mistakes and LOFT on the track . ( LOFT is a golf term ...lack of ....)
Must say it was a small challenge to go fetch cars and drive them back this morning and dodge all the roadblocks as our tyres look like full slicks at the moment . You always get road cars that want to race you . Well that v8 M3 should never have tried. It just puts into perspective how fast a 3.7 is with a 10/43 box .
Hi All
thought I would summarise what was done on the vehicle to get it ready, plus what the next steps will be..
1) Partly bolt-in cage (in front) and the rest TIG welded - The cross section to the Tunnel and to the rear uprights have made a huge difference and has really (i think) stiffened the car up nicely from a chassis perspective
2) New Exhaust system with NO middle silencer (one in the rear), which makes the car sound awesome, and has probably added a few hp
3) Sorted the prop - front and rear bearing
4) Race seat and harness
5) A MOMO wheel which has made the lock to lock ratio shorter and feels good and almost right in terms of turn-in
6) - The BEST and MOST effective change was the addition of the RON SIMONS KIT - this has TRANFORMED the car - it handles and corners almost flat, has NO understeer in slow corners, handles NEUTRAL in fast corners and has a little (which I love) Oversteer on powering out of corners... it is truly and amazing kit!!!!! (and I have NOT yet put the 32mm ARB)
7) Ferodo disks in front, DS pads and dot5 fluid, Braided hoses- works well - redid master clutch and brakes cylinders
Special oil for the g/box
9) Castrol GTX Racing for motor - seems to work really well
10) New Battery...
11) and the rest of the "race compliance items" - fire extinguisher, decals, kill switches, etc.
To Do Next:
1)VERY NB... Valve Springs MUST be replaced and checked --- getting valve "bounce" at +- 5800 rpm - will fit same as per Jim K book...
2) Will fit better cams - as per JK book as well
I reckon with the above and improving my driving and getting used to car, will be able to find about 1.5sec per lap - should be able to get down to low 1;19's at Zwartkops
10) New Battery...
To Do Next:
Hi All
second race now done.... NO PROBLEMS.... I have attached some pics of the event itself....
Question????
What do guys think of the "Body Roll" on my car??? - does it seem ok??? - Just a comment, as the parts from US (33mm ARB Bushes) have gone "Missing in Action" - never arrived!!!!, the car runs on STD ARB
Question????
- photo 52.JPG (80.98 KiB) Viewed 9139 times
- photo 51.JPG (76.71 KiB) Viewed 9139 times
- photo50.JPG (140.2 KiB) Viewed 9139 times
some more pics
- Quite a bit of traffic!!! - GREAT FUN...I remember this particular situation.... nearly got nose taken off...typical Porsche driver - Got past on next corner though!!!!
- photo 50.JPG (69.69 KiB) Viewed 9139 times
Hi Guys
been a while since last post - anyway, have been searching for a 3.0lt motor for the car (as it is one of the original 3.0 South African cars) so I can try get it back as close as I can to spec.....
Thanks to Kevin and Dom, we have found a 3.0lt 12v Motor (unfortunately for now it will have FI) - s
So now starts the next "project" of fitting this motor - Hopefully will gte it done for the next race in 5-6 weeks - Will be posting photos as we move ahead.
In meantime find pics of the "motor'
I am really excited about this, as besides the extra HP, we are starting toi get back to "original" specs..
Tx again to Kevin for all his help and input - appreciate!!!!! - and Dom for the Hard work!!!!!!
- 2nd pic of motor - eeds a good clean!
- motor 3.0 b.JPG (146.44 KiB) Viewed 8965 times
- pic of 3.0lt motor
- motor3.0 a.JPG (121.48 KiB) Viewed 8965 times
Great! 164 V6 right? What are you using for FI?
Hi
Yep... thats right.... will be using Gotech, plus will be making a "special" plenum...
Nice! i'll be using Gotech Pro in my Giulie, would you mind sharing the map?Joemart wrote:Hi
Hi
A small progress update and some pics....
The old motor is out, and we decided we would also do some additional "mods" and clean up...
so here find some pics - the new motor should be in during next week
- Engine bay - cleaned!!!
- engine bay2.jpg (131.18 KiB) Viewed 8877 times
Hi
some more pics of small progress
- Modified and strengthened clutch housing
- clutch housing3.JPG (45.78 KiB) Viewed 8861 times
- Tappet covers - cleaned - will "paint" the Alfa logo - not sure if yellow or red??
- tappets2.JPG (43.26 KiB) Viewed 8861 times
