Before the track day I spent some time changing the suspension set up and geometry. I swapped my custom bilstein coilovers to my other car to try out some adjustable coil overs a friend built for me. The options on the rear were I could run coil overs or separate springs. At this stage it’s separate with rear springs supplied by Richard Melvin.
- IMG_1615.jpeg (113.09 KiB) Viewed 10209 times
- IMG_1622.jpeg (127.48 KiB) Viewed 10209 times
- IMG_1629.jpeg (77.57 KiB) Viewed 10209 times
- IMG_1587.jpeg (120.39 KiB) Viewed 10209 times
- IMG_1584.jpeg (148.53 KiB) Viewed 10209 times
Interesting corner weights to compare to my standard original 3.0 road car at 1280kg vs front gearbox mount track car.
- Front mount track car
- IMG_7521.png (68.18 KiB) Viewed 10208 times
- Road car
- IMG_7522.png (92.43 KiB) Viewed 10208 times
As mentioned on previous page the head gasket went on the last session of the track day . Was not to upset as it had already done two seasons of racing back in 2007 .
So it was heads off and reskim time. I thought while the heads are off a whole lot of updgrades needed to take place.
It was not the neatest of head welding back in 2007 but main thing it covered all the valnerable spots close to the water jackets.
- IMG_1544.jpeg (112.47 KiB) Viewed 10206 times
- IMG_1541.jpeg (108.49 KiB) Viewed 10206 times
- IMG_0105.jpeg (86.7 KiB) Viewed 10206 times
Next up was new water pump, thermostat conversion from Jim’s latest book, a proper fan and fresh pipework.
- IMG_0258.jpeg (64.57 KiB) Viewed 10206 times
- IMG_0284.jpeg (99.2 KiB) Viewed 10206 times
- IMG_1752.jpeg (98.77 KiB) Viewed 10206 times
- IMG_1748.jpeg (99.36 KiB) Viewed 10206 times
I used to have sealing rings that sat on top of the sleeves . These rings had very sharp edges that bit into the heads to seal. Back in 2007 I had head gaskets made so I had these rings machined flat. Well so I thought . The were definitely not parallel.So now it was to make no rings giving max 0-06 protrusion coupled with one of my head gaskets I saved from 20 years ago.
- IMG_1749.jpeg (142.53 KiB) Viewed 10205 times
- IMG_1747.jpeg (113.2 KiB) Viewed 10205 times
- IMG_1745.jpeg (126.97 KiB) Viewed 10205 times
- IMG_1744.jpeg (87.39 KiB) Viewed 10205 times
New injectors fitted for much higher flow as noted previously from dyno session I ran out of fuel at 5600rpm .
New type are 340cc Bosch
- IMG_0075.jpeg (131.69 KiB) Viewed 10202 times
- IMG_1753.jpeg (134.94 KiB) Viewed 10205 times
- IMG_1800.jpeg (94.14 KiB) Viewed 10205 times
- IMG_1801.jpeg (107.88 KiB) Viewed 10205 times
One Humpty Dumpty was back together I pressure tested the water system system and just check did a static compression test. Well I did find water leak out of bottle so good news that was all
- IMG_1883.jpeg (161.57 KiB) Viewed 10203 times
- IMG_1881.jpeg (146.26 KiB) Viewed 10203 times
New idle valve , sump gasket refresh and coil packs
- IMG_1805.jpeg (156.25 KiB) Viewed 10205 times
- IMG_0282.jpeg (132.52 KiB) Viewed 10205 times
- IMG_2055.jpeg (72.31 KiB) Viewed 10205 times
Now it’s back to dyno to remap the new injectors . Probably only in new year. Some interior pics and that’s all. Comments welcome
- IMG_1924.jpeg (142.26 KiB) Viewed 10201 times
- IMG_2078.jpeg (151.76 KiB) Viewed 10201 times
- IMG_2077.jpeg (122.94 KiB) Viewed 10201 times
Weekend Warrior
Nice work, welcome back!
Yep ! All the cloning in FB is bullshit ! It definitely has its place .
I need to do a full post on the throttle body set up !!
Fantastic.
All this garbage on FB, I hope people comeback to this forum. FB is just so full of scammers and copy cats.
