Duk
Re: "Patches" MD's Final Racing Project
Post by Duk »
Screenshot 2024-03-30 at 08-46-35 transaxle upgrade's - ALFAGTV6 COM.png (85.14 KiB) Viewed 23950 times
Screenshot 2024-03-30 at 08-47-10 transaxle upgrade's - Page 2 - ALFAGTV6 COM.png
Screenshot 2024-03-30 at 08-47-10 transaxle upgrade's - Page 2 - ALFAGTV6 COM.png (68.46 KiB) Viewed 23950 times
Thank you. Job done. Got info.
Time for small progress top up .
Starting work on the hydraulics. Will post after its complete.
75 Instruments 1.jpg (235.94 KiB) Viewed 23570 times
Cold air filter box.jpg (246.98 KiB) Viewed 23570 times
Turret Vent.jpg (242.3 KiB) Viewed 23570 times
Save 4.5 Kg on tyre well.jpg (245 KiB) Viewed 23570 times
What's not to like about this project? It's just fantastic. Especially the roof opening for getting cheeseburger and fries takeaway orders at the local drivethru.
Hole in one Zamani !
The End.jpg (90.49 KiB) Viewed 23518 times
1 See you track side.jpg (238.17 KiB) Viewed 23518 times
No MD don't leave, this forum needs you! Your content is one of the best!
Weekend Warrior
Post by Weekend Warrior »
I'll second that, love reading your updates!
OK then I'll stop bagging you about your head box...
Duk
Post by Duk »
Even though MD is a splitter and abandoned us, I was having a think about TA breakages, especially as they are almost always the ring gear and pinion.
Now I am making a guess here about the distance from the main bearing plate and the centre of the diff housing, but I'll just use an arbitrary 300mm.
Using a material coefficient of thermal expansion calculator: https://goodcalculators.com/thermal-exp ... alculator/
300mm of Aluminium that has a temperature increase of 80*C, would have thermal expansion of 0.5328mm.
But 300mm of steel (the output shaft) would have thermal expansion for the same temperature change, of 0.312mm.
So the aluminium case would grow 0.2208mm more than the shaft would, with an 80*C increase in temperature.
By my guestimations, that would increase the ring gear to pinion clearance by, ummmm, 0.2208mm..............
I couldn't find any numbers for the ring gear to clearance/backlash numbers. But in my old Haynes manual for the Alfetta, using the special tool and the procedure in the manual, it talks about backlash numbers between 0.13 and 0.18mm.
It's probably safe to say that if during the backlash setup procedure, the case and the output shaft were heated up another 80*C, that the backlash numbers would go from being 0.13-0.18mm to 0.35-0.4mm.
Certainly food for thought and might well be justification for fabricating a steel rear half of the transaxle case. Yes it would weigh more, but the expansion of case and shaft would be (basically) the same.
KevinR
Post by KevinR »
Yes . I would like to see a follow up on this .
I'm all for it. Let me contact him again.
Duk
Post by Duk »
Some more thought on this blatantly hijacked thread.
Fabricating the rear half of a transaxle case would be a bit of a challenge to get right.
Having this part CNC machined from a solid block of steel would be doable, but probably not really cost efficient.
So how about having it 3D printed in something like 4130 (Chromoly)?
tturbotim
Post by tturbotim »
I'm not going to leave!
The chassis gods require a blood knuckle sacrifice.
