In my experience all the "race" rubber (i.e. A032R, 540S and such) always measure tread width.
I must say I find it difficult to believe you can fit a 225/630 in a GTV without cutting metal. (Unless you make it really high).
If the size is given in the "street way" the width is maximum section (also A032, A048). If it's in the racing form it's the tread.
Some sizes:
http://www.yokohama-motorsport.de/conte ... &Itemid=26
http://www.yokohama-motorsport.de/conte ... &Itemid=27
A 225/630 might be tight as it could be 240 wide but 225/50R16 (63 cm OD) is not a problem in mine anyway. And yes, it is low, and yes, I've given it a couple of rounds with Mr. Sledgehammer.
In the rear you can fit almost anything.
Some sizes:
