Page 36 of 38
Posted: Sun Apr 19, 2009 10:45 am
by kevin
Sorry Z , I got all the pics, they just took a while.
Posted: Sun Apr 19, 2009 1:05 pm
by Zamani
I will post more measurements of the airbox lid.
For the runners I got some 116 24V runners from Beninca as well. 42mm ID. Use std plenum but you need to really port the stubs on the plenum to get 42mm.
Posted: Mon Apr 20, 2009 10:10 am
by Jim K
48mm runners
![Question :?:](./images/smilies/icon_question.gif)
Aren't you guys going a
'little' overboard? Are you going for 5liters or 10krpm?...But I forget, that's where the huge 12v runners originated...
Posted: Mon Apr 20, 2009 1:34 pm
by Zamani
Not overboard, but over"bored ".
Posted: Mon Apr 20, 2009 1:47 pm
naah, over rated.
Posted: Mon Apr 20, 2009 8:45 pm
by kevin
Probably overboared. Just seen a good case of individual throttles which were to large gave less power than the ones from AHM. This chap went and imported the biggest size thinking he would get more power. It was dropped by 2mm in diameter and his 12kw were there.(changed on dyno) This is on 3.7l.
Posted: Thu Jun 11, 2009 9:54 am
by kevin
I bought a spherical bearing centre dedion bush for the race car from RS racing. I have just removed my polyurethane one which I bought from performatek and after three years of track racing its still perfect with no movement(wear). Upon installation of the new RS bush I need to know from anyone who has done it what did they use for spaces to stop the RS bush from moving in the dedion. The origional alfa bush has two aluminium rings. Do I use one of these ? I know its a press fit but soething must hold it in position.
Posted: Thu Jun 11, 2009 11:26 pm
by Dennis
Kev,
It's a press fit from the top. If it wants to move it will move down, and you can't fit the bush through there
![Wink ;)](./images/smilies/icon_wink.gif)
The two spacers you got with the SZ bearing will keep it firmly locked in the beam.
Posted: Thu Jun 11, 2009 11:52 pm
Geez Dennis, it's been so long since you put the Mac keyboard to use here, I thought you moved to SA to play professional tennis ?? !!
Got your track thing back together again ?
Edit: Got your update PM ,thanks.
Posted: Fri Jun 12, 2009 11:32 am
by kevin
Dennis I pressed it in but there was still a 4mm gap so i put one of the origional(new) retaining rings in and put four spot welds around edges so bush cannot move in the dedion. I understand the two spaces keep it firmly in position in the cross member but that will not stop it moving in the dedion. Reason why I spot weld the ring on top as it was easier than hammering the edges in in. Sadly this was all done before I read the post but im sure all be ok.
Posted: Sat Jun 13, 2009 1:50 pm
by kevin
pic of spot weld with rs bush in and type of clip used.
Posted: Sun Jun 14, 2009 9:38 am
by kevin
Tried assembling the whole rear including adjusting brakes before putting the dedion back. Its much quicker but you need another hand to balance the gearbox on the jack pad to raise it in to the underside of car.
Posted: Sun Jun 14, 2009 11:46 am
Ok, now I finally understand why you guys need so much differential lock.
You are one halfshaft short of a picnic...
Posted: Sun Jun 14, 2009 3:33 pm
Hahhaa. The Mats does it again ! If I were you Kevin, I'd get the fire extinguisher ready NOW cause the guys aren't gonna let you off without arse burning jokes for a while...good time to take that holiday to OZ now buddy..
Posted: Sun Jun 14, 2009 6:00 pm
by MR2 Zig
Just goes to show those Sarrf Effricans can run with one halfshaft tied behind their back....
